Question about Ingersoll Rand 2545/7100 Electric Air Compressor Start Up Kit 32305898
Compessor cycles on and off repeatedly - Ingersoll Rand 2545/7100 Electric Air Compressor Start Up Kit 32305898
  • 395 Answers
Have you checked for any air leaks on all the pipes and hoses on the compressor ? Air leaks are the most common cause of continuous cycling.
Posted on Aug 24, 2010
How do i put coolant in haier model # hwfosxc7 rb?
oh man
you ask the right guy
you need to vacume test a cooler first
then fill it
you cant just 'recharge' because the old coolant isnt there
because it leaked out
get real ffs widen your scope
usually the compessor is the issue
coolent leaks because of a leak in the cycle
Jun 04, 2015 | Haier Heating & Cooling
Knocking noise
2545 is a piston compessor if so you've got a busted rod on one of your cylinders , this will fail catastrofic and break out side of compessor but if caught early can still be rebuilt with a few new parts
Mar 18, 2014 | Ingersoll Rand 2545 pump,air compressor
Air hissing out of crankcase vent when not running also oil coming out of vent
You have a serious ring wear problem . The crank case never is pressurised.
Feb 02, 2013 | Air Tools & Compressors
When the tank is empyt the compessor comes on with no problem and runs until it's full, once pressure gets low the compessor should automaticly come on and refill, that"s when the compessor comes...
Hi mcfadden21...
Check and clean or repair or replace your compressor's unloader valve.
The unloader valve is suppose to discharge the compressed air from the tops of the piston heads to the outside to make it easy for the compressor to start when the pressure in the tank drops to the starting point.
Please take time to rate me thumbs up
Sep 15, 2011 | Air Tools & Compressors
Samsung split ac mdl # u24a2qc, system is about 10 years old. outside condensor operates fine until warmest part of day, then the fan on the compressor unit cycles on and off repeatedly although the...
I would guess that the motor is pulling to many amps, it could be to small (not the horse power as should be), could be bad incorrect fan blade (to many blades or pitch on blades) over loading the motor. I have seen fan motors get to hot and stop from a dirty coil. Take a garden hose and a nozzle use a solid stream carefully watching the fins don't bend by high water pressure. Throughly clean the coil every inch or it. Hope this helps.
Jul 09, 2011 | Samsung Heating & Cooling
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
We have a 2004 Honda Odyessy... A/C compessor not cycling at all
make sure you check A/C fuse and relay. Is the compressor **** on when you turn on A/C?.
Oct 04, 2009 | 2004 Honda Odyssey
How much oil compessor do i need to put in the new compessor for a lincoln 2001, and also how much 134a do i need to put in the compressor.
Use your dip stick. My Snapon a/c repair kit came with two dip sticks. There might even be more now. any auto parts store will have the oil in stock. When i ask the napa store to bring me some, it came in a qt bottle. With oz marks on the side. I sure hope i was of some help to you. Sawdust
Aug 13, 2009 | 2001 Lincoln LS
Emerson quiet cool cycles every 6 mins
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerator continuously cycles
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Apr 15, 2009 | Whirlpool Refrigerators
Ingersoll Rand 2545/7100 Electric Air Compressor Start Up Kit 32305898 Logo
41 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
