Question about Denon AVR-3801 Receiver
How do I get my DTS to produce sound from my denon avr3801. Using optical cable and will hear sound in the AUTO and PCM input but not in the DTS input. I have tried to set the onscreen digital assignment but still no sound coming from the DTS input mode. I currently have only 5 speakers connected just the standard surround setup nothing fancy
  • 4234 Answers
SOURCE: Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Posted on Jun 17, 2008
  • 2318 Answers
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
Posted on Jun 20, 2008
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
jimedington
  • 39 Answers
SOURCE: RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Posted on Jan 16, 2012
Hi, I have the Denon 1601 without controller heres how i set it up Ps3>denon (optical) Ps3>t.v (hdmi) But thing is i dont know what buttons to press i pressed everything no sound help
Hello
Use the DTS button to select Digital inputs.
optical or coaxial.
if you are using HDMI use selected video input.
hope this helps
good luck.
Mar 06, 2016 | Denon Audio Players & Recorders
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
How to connect a panasonic tcp50gt25 tv audio out (opictal) to a pioneer amp.with opitcal. i connect the cable but no sound,any idea for setting,i did the setting for optical on the amp but still no sound
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
Mar 12, 2011 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
Greetings- my denon avr2802 is connected to ps3 for blu ray movies, games and music. The ps3 image goes directly to tv with hdmi and sound from ps3 goes to the denon using digital audio cable. Sound for...
Set the receiver for auto audio input - I think that you are getting caught out between MPEG and DTS audio. If you have the wrong one for the audio source then you hear nothing.
Mar 07, 2010 | Denon AVR-2802
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Apr 11, 2009 | Denon AVR-1403 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon AVR587 Setup
red/white/yellow = composite
red/green/blue= component video cables + audio cables needed
the red/white= stereo audio
the denon 587 has 2 optical (toslink) inputs and 2 digital coax. These are surround sound cables basically, it's the only way to get true 5.1 dolby or dts.
connect cable box, and the samsung to the sony using hdmi. then connect the cable box and the samsung to the denon receiver with optical cable. And that's it.
Jan 15, 2008 | Denon AVR588 Receiver
NO DTS option on Yamaha 5730
you have to use the optical cable input for the dts options to work i just had to do the same thing and now it wrks perfect!!
Hope that helped!
~s~
Nov 04, 2007 | Yamaha HTR-5730 Receiver
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Denon AVR-3801 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
