Question about Minolta EP4000/5000 CS/PRO Copier
I have a minolta 4050 that is showing a c0040 error code
  • 40 Answers
Thers fan for transport motor this fan not working fine check it
Posted on Sep 01, 2010
Error code c0040
C0044
ADF Cooling Fan Failure (Only when the optional DF is mounted)
- Refer to the option service manual (DF-605) for details.
Feb 10, 2014 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE C0040 ON MINOLTA 4000
Suction fan motor fault. Check all vents also check all fans!
Nov 29, 2013 | Minolta Office Equipment & Supplies
DI620 error code c0040
Suction fan motor failure located under the drum and transport belt unit
Jul 21, 2012 | Minolta EP1030/1030F CS/PRO Copier
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
I have a minolta 4050 that is showing a 601 error code
SC 601 = SCP board PWB J malfunction or scanner motor malfunction.Scanner motor located in rear parts right side and the PWB J panel in the right side of copier.Try open and closed the front door,push the trouble reset switch,if the error code persisit change the scanner motor or PWBJ.Move the scanner manually,turn ON the power switch,if the scanner exposure lamp move,working the scanner motor is OK.Check the scanner home position sensor.
Oct 30, 2011 | Minolta EP4000/5000 CS/PRO Copier
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro 4000 with error code C:C0040
Fan motor, open close front door, to reset.
Oct 28, 2010 | Minolta EP4000/5000 CS/PRO Copier
C 0040
C0040 is a cooling fan failure code. Opening and closing the front door wil reset the code. Doing this while "bumping" the machine will restore the machine to operational MOST of the time. Cooling fan replacement will eventually be required. Resetting though can be accomplished in most cases.
The part number for the fan is 9313-1310-61 and here is a picture of the fan which is located behind the rear cover.
Jun 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
C200 code
C0040, Suction Fan, failure to turn.
The fan under the transport belts is not working.
The fan will likely have to be replaced.
Hope this is of some help.
Ed
May 21, 2009 | Minolta EP4000/5000 CS/PRO Copier
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
244 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
