Question about Swisher 44 Iinch 11.5 Hp Trailmower #T11544
What causes the grass to row up?. We've had a rainy summer and sometimes the grass gets a little taller than normal.When it rows up and turns brown the yard is very unsightly. It seems to be coming out thicker on the side where the bar attaches and leaving the rows. Do the blades need adjustment or is it because of damp grass? Thank you, Kathy
  • 755 Answers
You may have worn blades that dont overlap anymore.
You should take your blades off and have them compared to new blades and see if they are a little shorter than they used to be.
If not....have them sharpened and put them back on. Check your Swishers belt tensioner to make sure the blades are all turning freely.
Posted on Aug 24, 2010
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
Repair flipdown monitor on 2008 town and country
Town and Country, Grand Caravan, and Routan are all having this same problem with the VES. 2nd row screen is blank and 3rd row screen shows split screen with no signal. Here is the fix.
http://www.youtube.com/watch?v=4jBndxy8rpg
Get the cable from here.
http://www.ebay.com/itm/2008-2009-2010-2011-2012-Routan-Caravan-Town-Country-VES-2nd-row-Monitor-Fix-DIY-/151057952865?pt=Car_Audio_Video&hash=item232bc17061&vxp=mtr
Jun 29, 2012 | 2008 Chrysler Town & Country
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The riding mower does not mow small strips in the middle of the row being cut. It almost looks like a bad haircut? This happens when I am going fast or slow. It is not a mulcher. This problem is...
Sounds like it is time to replace your blades, I have 2 scotts mowers made by john deere both machines are 9 years old I mow comercially and get 4 to 5 sharpenings the they need replacing.
Oct 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Regarding the value to be know
Yes, you would do a LOOKUP do display the row number.
LOOKUP(H53,A1:G1000,0)
Feb 18, 2009 | Microsoft Computers & Internet
Cigarette lighter not working, no power to it, can you tell me where the fuse is located for it
The fuse for the cigarette lighter is located in the fuse box on the driver side of the car under the dash. It is a blue 15 amp fuse.
When you open this fuse box, you will see some larger relays with 4 rows of fuses below it. The fuse you are looking for is the first fuse in the 2nd row. in the 2002 X-type, that fuse is a little taller than the other ones.
Thanks for using the fixya forums!
Jul 07, 2008 | 2002 Jaguar X-Type
Swisher 44 Iinch 11.5 Hp Trailmower #T11544 Logo
113 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
