Question about Karcher K DS 5500 Vacuum
KARCHEN 5500 My vaccum has 6 years old and the problem is that it does not work properly (wet vaccuming process). From the model overview I need Carpet turbo nozzle and the water filter. My email is patriciaperdomo43@yahoo.com Thank you very much Patricia Perdomo 786-2620411
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
After the dc16 is charged, I try using it but it only works for about 30 seconds and then it stops. I've had the vaccum for about 3 years. I need a solutions. Could it be the battery?
Almost certainly the battery. 3 years is pretty good for those batteries. Normally batteries can be changed by suitably "interested" people, but I don't know about that specific model. Check out the replacement price of the whole thing compared to the replacement price of just the battery before you jump in though.
Nov 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Looking for manual
i have filter queen vaccum model at 1100 that was past down to me i need user manual
Dec 11, 2007 | Vacuums
Karcher K DS 5500 Vacuum Logo
129 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
