Question about Black & Decker Electronics - Others
I bought a new Black and Decker 200 watt power invertor to plug into our car cigarette lighter to power a laptop. We did this and our car blew a fuse. We went to Saturn to fix it and they could not understand why. The cigarette lighter was ok when we used it to power an ipod. Why won't this work?
  • 843 Answers
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Posted on Aug 23, 2010
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
Trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
May 26, 2010 | Black & Decker Black Decker 400 Watt...
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
Charging laptop in car
Most inverters create a modified sine wave output, which is similar to, but not the same as the AC you get out of the wall. The power supply for many laptops (and most transformers in general) will not run with a modified sine wave input. There are devices available that skip the inverter and the power supply. They go directly from 12VDC to what your laptop needs.
Apr 23, 2010 | Black & Decker 200 Watt Power Inverter...
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
How many Watts on the B & D M205S
200 Watts! I have owned the M205S for 15 years! YUP! and used it to death! Doesn't owe me a penny! But I am so upset, because although the 200 Watt motor is still running great, one of the beaters just broke off. I didn't know if replacement beaters are still available for such an old model?
Dec 31, 2007 | Black & Decker 200 Watts MX85...
Electronics - Others Logo
290 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
