My reverse light is not working and it's not the bulb and there is no power to the wire all the way to under the dash,what can the problem be?
    Sergeant:
  • 221 Answers
Probably a blown fuse, Look in your owners manual and find out where the fuse is located for the reverse lights. Locate the fuse under your dash, or under the hood, whichever applies, pull the fuse and take it to the auto parts store to have someone help you find one.
Posted on May 04, 2008
Stuck in park,power windows don't work,reverse lights don't work dash doesn't work. keeps blowing 10 amp fuse for reverse lights.changed brake pedal switch didn't help
of course changing a brake pedal switch will not help in a reversing light problem
they are two totally different circuits
check for a damaged wire at the reverse light switch or bulb holder for the reversing bulbs for a dead short
as for the rest check the IGN fuse under the bonnet
Feb 18, 2016 | 1997 Honda Accord
My brake lights wont work everything else back there works just no brake lights what is causing it and how can i fix it
check if there is a brake light switch under the dash at the top of the brake pedal as it may be loose or a wire has fallen of the connection
Oct 29, 2014 | 1996 CHEVROLET SUBURBAN 1500 Grille...
My dash lights will not work how can I fix this
Do you have any mileage programmer, use the to reset the dash system.
Jul 31, 2013 | 1988 Mercury Tracer
Right Signal Light Not Working clicking fast on dash
You could have pinched a wire. Check to see if there is power going to the bulb by using a test light.
Jun 18, 2013 | 2005 Ford Falcon 4.0
I have a 2004 silverado. My cargo light isn't getting any power. My third light works fine and when i reverse the harness the cargo lights work. I'm assuming its in the wiring. Do the two wir
There should be 12 volts on the orange wire at the bulbs. The switch controls the ground side of the circuit. There should be 12 volts on the blue w/white wire at the switch. The switch will ground that wire and complete the circuit and the cargo lights will turn on.
to check the switch you would unplug it and check for continuity between the pins that the blue w/wire wire and black wire go to.
Feb 24, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
I have replaced reverse light bulb, however new bulb will not work. I have checked the bulb, the fuses and the wiring, any ideas why can't get it work. Also indicator on dash still present.
The reverse light switch is a mechanical device used to control operation of the vehicle reverse lights. The switch is designed to complete the circuit when reverse gear is selected allowing reverse light operation (manual transmission only).
Aug 04, 2011 | Audi A3 Cars & Trucks
I have a 1991 chevrolet k1500 truck i have no reverse lights and now no tail lights, i have checked fuses all good, i replaced all the bulbs both sides of truck and replaced bulb holder tray on each tail...
sounds like you may have a wiring problem at the back of the truck right side underneath behind the bumper were the wires travel from the front to the rear of the truck, if you check the wires for damage, broken,green corrosion or rubbed through this is common for these trucks,check all the wiring at the back in these areas.
Mar 18, 2011 | Chevrolet C1500 Cars & Trucks
1988 pathfinder no dash lights no revers lights no tail lights no gaiges
If they all stopped working at the same time then it is probably a fuse or possibly 2. Check your fuse panels in the dash and under the hood. The dash lights and gauges should be a fuse labeled instrument cluster or guages, it is probably blown. The other fuse to look for will be the tail light fuse. This is where I would begin.
Sep 23, 2010 | 1988 Nissan Pathfinder
Brake light, reverse light and turn signal issues
Hello. The symptoms you are describing are likely due to a poor ground. Temporarily install a new ground wire by securing a piece of copper wire to the frame with a self tapping screw. Use this ground wire along with the hot wire to see if each of these lights works. If it does, trace the ground wire back to the frame, unscrew it and clean up the metal with emery cloth so you reestablish a good ground.
Jan 28, 2010 | 2003 Ford Windstar
92 toyota camry e electrical question
I had the SAME problem with my 1992 Camry LE...except without the water..First, check the back up lamp fuse (there is more than one circuit on that fuse, not sure which). The water would have likely shorted out the circuit. First check for power at the reverse bulb while the car is in reverse (You can do this with the car off) If there is power, check the ground wire, if it is bad...if you splice the ground wire before the connector and run a new wire to a ground in the trunk, then it should work..thats what was wrong with mine..hope this helps
Apr 16, 2009 | 1992 Toyota Camry V6
Computers & Internet Logo
David Payne
David Payne
