Question about Refrigerators
I need to know the correct part name or number so i can order it. Punctured the coil inside of the fridge. Its the white thin metal plate hooked inside at the top. I think it serves as the freezer section as well as a coil.
    President:
  • 670 Answers
The coil inside the freezer is the evaporator coil. You probally need a refrigerant technician to properly install and charge your refrigerator.
Posted on Aug 23, 2010
I have KIC frigde it is hot intead of cooling
Could be a number of things.... no freon ( somebody tried defrosting the freezer with a knife & punctured the coil, the fridge might need defrosting..... do you have power to the fridge?
May 07, 2017 | Refrigerators
IF REFRIGERATOR EVAPORATOR WILL BE PUNCTURED BY ANY REASON SO WHAT SHOULD I HAVE TO DO? MAGIC DEPOXY CAN STOP THE PRESSURE OF REFRIGERANT OR GAS WELDING WILL BE BEST WAY?
all refrigerant mechanics will tell you that a punctured evaporator is the death of the fridge
the metal is too thin to weld and any glue used will blow off under the pressure of the gas
basically the cost to effect a maybe repair is more than another fridge.
Aug 08, 2015 | Refrigerators
My breeze unit blows a fuse when turned on,,,the fuse in the unit
First of all, make sure that the replacement fuse is the EXACT size required. Check to see that all contact points in the machine are pressing firmly on the inserted plate. You may need to turn the white posts to adjust those metal contact fingers, or bend them so they're firmly in place. The plate may be broken or dirty. Order new plates at 1-800-989-2299 (Vollara is the new name of the company.) and give 16618 as the dealer referral number.) Look to see if you can see any obviously loose wires inside, also. If none of this helps, contact us at fredandmb@frontier.com and perhaps we can help you. The Breeze is no longer being marketed/repaired at Vollara, but we do have some parts and machines in our older stock.
Feb 07, 2011 | Ecoquest Breeze AT Living Air Purifier
I need to know if model # on medal plate on back of machine is
Yes, it will be the correct manual. I found the manual at http://www.sewingmanuals.com/Sewing_Machine_Manuals/White.htm if you needed to know where to find one.
Happy Sewing!
Robbie
Aug 02, 2010 | White Sewing 1888 Mechanical Sewing...
I was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Dec 12, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Eaton Viking mini fridge not getting cold
yes. you certainly need to get a technitian out there. it seems that you are having a shortage of gas. if you have a gas shortage, then there must deffinitly be a gas leak somewhere.did you recently try to clean the plate that you mentioned with something shap? if so then you might have punctured it and that is where your gas leak might be. you do get special epoxies that you can do a quick fix, but you will still have to send it to a repair shop to regas and evacuate the unit. good luck
Sep 07, 2009 | Viking Refrigerators
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Beer dispencer brewmaster Model#HBF05E
If you punctured the evaporator plate, you will need to replace the entire plate, which means brazing a new one in, evacuating the unit, and replacing the refrigerant charge. If you can't defrost the coil, unplugging it with the door open, would work much better than chipping at it.
Jul 03, 2008 | Haier (HBF05EAVS) Beverage Dispenser
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
