Question about Hitachi Televison & Video
I have an older 60 inch ultra vision and has been a gr8 tv i came home the other night and turned and the screen jumped for a couple minutes and then stopped and was fine still gr8 pik but my daughter said did same with her and she tapped it lightly on he side and it stopped is there something loose that will bean easy repair or will be better to get a newer one this one is about 13 or 14 years old first prob ever
Mitsubishi wd 62527shows purple and yellow clouds and a big blue spot in the bottom right hand corner of the screen is it worth fixing? yes or no needed
Posted on Aug 23, 2010
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Why does my truck stall after a few minutes leaving no electrical at all?
sounds like a fuel injection or fuel filter problem
cleaning the injecters should help and changing the fuel filter should also help
May 16, 2014 | TopGearAuto Ford F250 1969-1979 7 Inch...
60 inch lg plasma bottom cut off tv
Check this site for more details with illustrations. You can get the cause to this fault. Pull up older posts there. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | LG Televison & Video
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
My Hitachi Ultra Vision 50 inch big screen (projection) tv has a ghost look around everything. Please help me and tell me how to fix this at home. Thank You, Dustin Kellems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 18, 2008 | Televison & Video
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
