Question about Lincoln Electric Ranger Gxt 250 Amp Generator/Welder 125 Volt, 250 Amp, Model# K2382 2
My lincoln welder has auxiliary power, but will not weld
    Scholar:
  • 97 Answers
There is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Posted on Aug 31, 2010
3 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Posted on Sep 22, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
I have a lincoln sp-135t mig welder. while i was welding it started to just blow gas and i could weld with out pulling the trigger. also when the welder is plugged in but turned off the unit is still...
Contacts of the main contact relay "CR-1" are likely fused together completing the circuit. Otherwise the trigger switch is fused closed.
The main contactor can sometimes be released, then dressing the contacts with a small point file (Small mill ******* about 1/4 inch wide and 1/16 inch thick.
Otherwise locating a contactor/relay of a suitable current rating with a control voltage/coil rating of 24 volts.
Jan 02, 2012 | Lincoln 210 BLUE Welding Tools
I own a Lincoln 305gas powered welder I recently purchased a Lincoln 25M suitcase and wanted to know if the two were compatible before I tried them together and if I can weld aluminum with them hooked up
Hi:
Yes your 25M feeder will work perfectly with ANY engine drive welder. Regarding the aluminum welding that's a no, sorry but suitcase feeder and gun are specialty made for mild and SS welding. For the aluminum you will require a spool gun and N adapter for your engine drive. Check you onwer's manual for more details.
If this was useful to you, please vote. Thanks.
Mar 27, 2011 | Lincoln Welding Tools
Wiring diagrams for lincoln sa-200 F-163 welding machine
try Westermans - used welding machines supplier. They stock the best brands like Lincoln, ESAB, Kemppi and Fronius. They should also have operator manuals for most machines. email them at welding@westermans.com ask for Craig.
Sep 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Mar 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
Mar 17, 2009 | Welding Tools
Lincoln Electric Ranger Gxt 250 Amp Generator/Welder 125 Volt, 250 Amp, Model# K2382 2 Logo
548 people viewed this question
Top Lincoln Electrical Supplies Experts
 Kenneth
Kenneth
John Trevino
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
