Question about Kenmore 24032\24036 Top Load Washer
I keep getting a UL code which means unbalanced load..Open the machine and look at the cloths shut the door and start it back up 10 min's later wash is done . Looking at the manual it says machine is un even so I checked it made minor level adjustments...
  • mark_john683 Aug 25, 2010
    The actual model is 110.2706 Kenmore Elite HE type 580 I get the UL code ..I did run it empty and same thing I was reading another personson submission and they were told it would possibly be the the drum bumpers.. Don't sound complicated if I kne what I was looking for ..
    anybody got a clue is it the drum bumpers?
  • 10,515 Answers
This is usually a common error. You need to unplug the machine for few minutes, say 30 minutes and then turn it ON, it should reset the error.
If not, the next details you need to check :-
1. Is it accompanied by some other error code?
2. any other problem that sounds in relation with this code?
If not, it refers to faulty control board. Many people have got even error PF ( power failure ) along with it. Once replaced, it would fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 25, 2010
  • taran_2005
    taran_2005 Aug 25, 2010
    Thanks for your response!!
    I have never seen drum bumpers as a cause on this model. As i cannot see the machine, i could only share my experience on these machines.
    Hope i helped you.
UL code keeps coming up at last 9-10 min of spin cycle will not finish load What could be causing this? Is it bent suspension rods?
I replaced the suspension rods but it not resolve the UL issue - still gave UL code even when run with no clothes in load -so I called Maytag for service.(Purchased REPAIR PLUS 1 which covers this repair and one year maintainence contract). Tech from local subcontractor service came out and said it was the bearing. I am still waiting for repair 10 days later because service contract required "approval" before he could order parts (7) including rotor and sensor although to fix bearing tech should only need bearing kit & tool to pull old bearing.
May 20, 2016 | Washing Machines
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
MTW6600TB1 code U L
Hello. The UL code means the washer is unbalanced. Try taking out clothing around the middle and readjusting to the edges. That should help take off the code. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 28, 2012 | Maytag Bravos MTW6600T Top Load Washer
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is leaking from my washing machine when I am washing clothes and I keep getting the LD error code and UL but it is not unbalanced.
Grab hold of the inner basket & pull up & down. Does it move up & down? If not clothing is stuck between the inner & outer basket. Tilt the unit back & use a flash light & shine it through the clear plastic & see if you see clothes in it.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul on dial. unbalanced load on small load
just that! You need to rearrange the cloths to put the balance back in the drum. If its wobbly it will make a noice a banging sound or squealing sound.
Aug 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Ul code up and before that just cut off during load
The ul code is unbalanced load. Try adjusting the load. If it happens again try removing some of the clothes.
Mar 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
