Question about Panasonic NN-T990SA Microwave Oven
Panasonic 1300 watt NN-S654BF microwave stopped cooking. No matter how much time is entered, after cook is pressed, the microwave runs for 23 seconds and the display returns to the clock as if it had run through the entire cycle. The fan and the carousel run, but the extra power draw of cooking is not heard nor is the food warmed.
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
SOURCE: Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
garing
  • 998 Answers
SOURCE: Panasonic Microwave turns on and tray rotates when door is opened
check the door switches
Posted on Aug 16, 2009
fathitkf
  • 1871 Answers
SOURCE: 1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Posted on Apr 04, 2010
Testimonial: "Thnaks; If this is my problem, how is this switch replaced, is it a proffesional job , or simple? Thank you kind sir.T.K. tkeytanner@gmail.com"
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
I have a panasonic nn 2501, .You can set the time, hit start, the time will run , but the microwave does not run. What is up? Door safety switch? Thanks, VIC
you are setting the time on the microwave clock , your press the wrong button ,you can try just putting in the number of mins and press start, or theres cook then time and start. if helpful plz rate..
Jan 19, 2011 | Panasonic NN-S251 Microwave Oven
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
Hello :
best regards .
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
MW stops after 23 seconds.
PLESE CHECK RELAYS ON PCBOARD .ALSO TRY DISCONNECTING ALL CONNECTIONS TO FRONT PANEL LEAVE IT DISCONNECTED 5MIN THEN RECONNECT AND TRY THE ELECTRONICS SHOULD RESET .HOPE I HELPED BIT OF A WEIRD FAULT
May 09, 2007 | Panasonic NN-S553 1350 Watts Microwave...
Panasonic NN-T990SA Microwave Oven Logo
63 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
