Question about Sony Alpha DSLR-A900 Body only Digital Camera
Camera error in sony alpha a900 - Sony Alpha DSLR-A900 Body only Digital Camera
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Not readable CF
After you inserted the Compact Flash card, you have to format the card in the camera. If it was used in another camera there is always a possibility your camera can't read the existing file system. Make sure you saved all pictures on the card, in a computer, using a memory card reader. Only then format the card in the camera. Then you first have to shoot a picture, before you can see one.
Make sure you close the memory card cover, before you try to do anything with the card.
Never open the camera, or remove the battery, while the memory access light is still flashing. This could damage the filesystem.
If you already did so, try to recover the files in a card reader connected to the computer. There is free recovery software on the net.
Feb 17, 2014 | Sony Alpha DSLR-A900 Body only Digital...
I m using sony alpha 330 dslr cam but recently i am getting camera error displayed on screen but though m able to click pix. so if ne1 can tel me what the error is about?? Thanx
there is something wrong with your lcd screen or shutter button.you can send to the professionally maintance center or yourself find the replacement on the website.
www.skiliwah.cn/
MSN:e-8090team@hotmail.com
Aug 17, 2011 | Sony Alpha DSLR-A330 Digital Camera
Mi camara da herror de las Naciones Unidas Herror code = 0x59
On my Sony Alpha 100 I keep getting this error 0x59 when I press the shutter button. It takes the picture but I have to turn the camera off and then back on to use it again
Oct 23, 2010 | Sony Alpha DSLR-A100 Digital Camera
Shutter will not trigger
it may be a loose wire (children? dogs?) it's a strange one though, maby just had it's day
http://finnsharp.daportfolio.com/
Apr 16, 2010 | Vivitar Wireless Remote Shutter Release...
Fine Pix A900 Memory Card
make sure camera supports a sdhc type card-if not go back to a 2 gb and you will have no probs
May 19, 2008 | Fuji FinePix A900 Digital Camera
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 won't acknowledge memory card
I would suggest that you give the camera to Sony service to have a look at it. The regular shop would not have the proper test facilities to properly diagnose any in depth problems with this type of camera unless they were an authorized contracted service rep. The problem may be involved.
Jerry G.
Feb 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A900 Body only Digital Camera Logo
230 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
