Question about LG 26LG30 26 in. LCD TV
26" LG LCD TV. Won't turn on and there is no red power light on front panel. Switched out lets, same thing. Is on surge protector. Was working fine.
  • 3 Answers
SOURCE: Blank Screen/Powers up, Power LED can be switched from ON (Green) to STANDBY (Red)
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Posted on Feb 12, 2009
SOURCE: Red Snow on HDTV
I had the same problem, and it drove me nuts. I called the store where we bought it since we still had a warrenty. They replaced a (horizontal deflection/scanning?) card on the set, and it got much better. I could, however still see a tiny amount of red, so the tech adjusted it again to show me how much better it was now, but in the process, there was a flash and a loud pop - and the set was no more. They ended up replacing the set. So, there is a solution, but be careful who installs it.
Posted on Feb 28, 2009
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
SOURCE: LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Posted on Sep 01, 2009
dsacco86
  • 1077 Answers
SOURCE: My lg tv wont turn on.
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Posted on Sep 09, 2009
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Where do I find the part number on the power board for my LG 47LH40
You have to contact the authorized service centre for LG, to get an original replacement.
Jun 28, 2013 | LG Televison & Video
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
Blinking red light in front of tv (lamp) and noise coming from tv as well.
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2200. You can download the manual of the TV by clicking here. Refer to page # 76 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KDF-E55A20 55 in. LCD Television
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
I have an LG 42lg50 TV that was working fine earlier today, While I was out of the house an Thunderstorm came up and power failed at least twice. I come back home to find my TV not working properly. The...
An electrical pulse from the thunderstorm has affected your TV. (Was it on a surge protector?)
There is a small possibility that it will come back.
Unplug the television and let it sit for an hour or more and then re-plug it.
If you need to get a new TV, also get a good surge protector such as Panamax.
Jun 14, 2010 | LG 42LG50 42 in. LCD HDTV
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
No indicator light or power
Please look at these two links; I suspect your problem is related:
http://www.fixya.com/support/t4592070-tv_no_power_will_not_switch
http://www.fixya.com/support/t4596948-tv_stopped_working_bit_fizzing
This model seems to be having a ton of power supply problems.
Apr 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Sound without picture unit did not go thru auto set up input will not display
returned defective unit to the store after talking to them and determining the menu would not display.
Jan 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
LG 26LG30 26 in. LCD TV Logo
346 people viewed this question
Computer Repairing
Computer Repairing
