Question about Dell Dimension 4600 PC Desktop
Can't boot up
I accidently pulled out about 5 little prongs that come from the on off switch on my computer, I tried to put them back in order, but, to no avail, the computer won't boot up and it said that the floopy drive, cd rom drive and the scsi drive can't be found, how do I fix this problem?
  • Mark Kessler May 11, 2010
    Did you pull the prongs from the switch itself, or from a connector on the motherboard?
    Problem Solver:
  • 15 Answers
Well from what i know, if it cant find a certain hardware during boot up means its simply disconnected from the motherboard. u can change the boot up sequence usually by hits f12 during  boot up. it should say hit f12 or a button to enter booting sequence or words along those lines.. simple go to hardware from there in the BIOS, and disable the hardware u dont want to boot.
Posted on Aug 04, 2008
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 05, 2008
  • 197 Answers
My suggetion is to read throuth your owners mannual and see if you can find a power sequence for it , it should show how to plug the wires back in in the right slots , if you have pulled the wires off the the on and off swithch the you need to send it back to dell
Posted on May 04, 2008
  • Doug Hudson May 04, 2008
    continue : go to dell homepage and click tec support and it will take you a window find chat with tech support and will ask for the computer name and you will have to scroll through and find 4600 then it will bring up a pic of your tower right next to that is a link for a manual you will have to unzip it then you have to look throught that for power display
Changing interior light on GE jvm1790
1. Unplug Oven
2. Unscrew 2 screws on top front of oven
3. Pull of front vent (might need a little force the
first time but not to much or you will crack
plastic)
4. Unscrew screw facing you near the front that is
attached to metal plate on bottom of opening
behind the vent.
5. Pull out metal plate (box) carefully not to
damage any wires.
6.Bulb is in this metal box, pull out old one and
press the new one's prongs into holes (be
careful and gentle the bulb breaks easily,
don't try to pull it back out to see if it's all
the way in or you will most likely pull a
prong out of the bulb)
just firmly press bulb
into place.
6. Screw metal plate back in place.
7. Plug in oven and test bulb.
8. Unplug oven again and put vent back on with
the 2 screws.
9. Plug in, set clock and your done.
The first time I opened it up was to look for the bulb. The vent needed a little pulling to come off. The second time (to put in new bulb) it came off easier and whole thing took about 5 minutes.
Hope this helps.
Just in case: I am not a professional nor claim to be. This is based on my own experience. Yours may differ. Unless you feel totally comfortable you should contact a licensed electrician or an authorized service agent.
Oct 18, 2010 | GE JVM1790 Convection / Microwave Oven
EMachines T2958 Destktop Computer Power Problems
There are several things to think about here. First off, you have *six* wires ... 3 pairs ;-)
1. Your computer only *NEEDS* to have the power switch wires (the black/white pair) connected, so if you can figure out where to hook these up, the computer will work. The "LED"'s are just lights so that *you* can tell it's on and when the hard disk is being used.
2. I can't say for sure, but most manufacturers put these wires into some sort of arrangement that plugs into a one-way connector ... in other words, the wires are all ganged together in one "plug" and there is a tab or projection or slot that keeps you from putting the wires in the wrong way. If your wire sets are connected in one plug, it's should be fairly simple. From the sound of it, though, they're separate, so keep reading.
3. Make sure your computer is plugged into power. Take a pair of needle-nose pliers with rubber handles and place the point between each set of two prongs, so it is "bridging" between them. You will be completing a circuit with the nose of the pliers (it's fairly low power, but use the rubber handled pliers anyway for safety). When the computer starts, you'll have found the two prongs that the black/white pair should be attached to. It doesn't matter whether the black goes to one and the white to the other; it's just a switch.
After this, you've only got 2 wire pairs and 4 prongs left, so trial and error should allow you to connect the other wires. I'd start with the Green/White pairs first. When the computer is ON, the LED for power should also be ON.
Good luck with your troubleshooting!
Apr 27, 2010 | Computers & Internet
Headlamp replacement
1. Unplug the three-prong electrical connector.
2. Pull off rubber boot on back of headlamp
3. A spring clip holds the bulb in the assembly. Un-hook one side and swing the clip back.
4. Slide the old bulb straight out.
5.Wearing disposable gloves so that skin oil doesn't get on the new bulb, open the new bulb's package and insert the new bulb straight into the holder, making sure it goes all the way to the front. The middle electrical prong should be up.
6. Swing the retaining spring back and re-clip.
7. Slide the rubber boot back on the rear of the assembly, making sure that the electrical prongs are exposed.
8. Re-connect the three-prong electrical connector.
9. Turn on lights and make sure it works.
Oct 13, 2009 | Mazda MPV Cars & Trucks
I have latitude CPx500GT can you plz tell me unlocked a administrator password.... Thnx..
hi, unplug the pc- remove the lithium battery on the board-find the jumper on a three prong header-move it 2 the reset bios position-push the power on button, or wait 5 min-then put it all back to the way it was-then boot up.. make sure you set the correct values- bus speed-boot order-time and date-ect. if you need further help-reply. good luck! and please rate this solution. be well!
Jul 12, 2009 | Intel Motherboard
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
Mother board
about the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
May 03, 2008 | Computers & Internet
Cannot get out of running windows normally
You didn't loose you work, windows only got corrupted as what often happens. Start up into safe mode, then run "scan disk" and select fix errors automatically, it might take a while to run. Maybe with a little luck it might find some errors and fix it.
Worst case situation - put the hard drive in another computer that boots in order to back up work, then put it back in your machine and buy a copy of windows xp. Then install drivers from Acer's website. (might have to use a jump drive with another machine to install first network drivers on your machine)
Hope this helps maybe a bit......
Apr 25, 2008 | Acer Aspire E360 PC Desktop
Main menu / positioning /
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Oct 03, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
The Menu always shows
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
May 19, 2007 | Relisys TL 766 Monitor
Dell Dimension 4600 PC Desktop Logo
64 people viewed this question
Alun Cox
