Question about Ricoh Aficio 2022 All-In-One Laser Printer
Lanier 5622, "WAIT" apear and nothing happen...
  • 903 Answers
When the machine stays at the "Please Wait" message and nothing else happens, the most likely cause is the hard drive. The hard drive will need to be replaced in order to restore full functionality. You can disconnect the hard drive to make the machine work in the meantime, but you'll lose some functionality.
Posted on Feb 15, 2011
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
Feb 07, 2013 | Sub-Zero 700 Refrigerator Freezer...
Playstation lights turn on, But nothing apears on screen?..........
Did your previously had it hooked up through hdmi????? Are you getting sound????? Try with the standby light on pushing in the power button and holding it until you hear a beep or two then let go....wait a few 10-15 seconds and see what happens....
Mar 28, 2012 | Video Game Consoles & Games
Lanier 5622 says following output tray is full please remove paper. However it can be empty, half full, or completely full of paper and this error will not go away. Just replaced the photo conductor...
Hello!
Why did you change the fotoconductor Unit???? This part of the machine is to create the image.
Your problem is in the tray. Meaby a broken switch. Take out the all tray and look inside to see if there is same obstruction.
If you do not see anything i advise you to call a Tech.
Dont waste more money if you dont know what your doing. This is the best advise i can give you.
See you!
Aug 31, 2011 | Lanier 1205 Copier
I have a lanier ld122 copier/fax. It told me to add toner, i did, and nothing happened...still says add toner. what do i do now/
First of all check if the doors are well closed.
If everything is well closed you can have several problems:
1º Toner supply defective.
2º TD sensor defective
3º Development unit defective.
If you don't have technical training i advise you to call the provider.
Feb 28, 2011 | Lanier Office Equipment & Supplies
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Got a function code SC322 on lanier 5622 copier. Power cleared the unit several times but status remains unchanged.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
Sep 15, 2010 | Lanier Office Equipment & Supplies
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
205 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
