Question about Cisco 7940 IP Phone
Does not ring when dialed - Cisco 7940 IP Phone
    Champion:
  • 331 Answers
Check your volume level. (press the volume button) and be sure to save the settings.
Posted on Aug 27, 2010
How is open the lock
Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
May 06, 2015 | Luggage & Travel
How can I get more than 3 rings? I am in my 70s and disabled. I can not get to my phone to answer in 3 rings. I miss calls due to this.
  1. Pick up the home phone receiver, wait for dial tone, and dial *94. You'll hear 3 beeps followed by dial tone.
  2. Enter the number of rings you want (between 2 and 9).
  3. Listen for 2 confirmation beeps and hang up.
Dec 11, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Jun 28, 2011 | Panasonic KX-T7630 Corded Phone
How do you change number of rings for the phone and auto attendant
You need to go into phone system admin programming
feature 00
left intercom
left intercom
Then the program for the ring delay on the Lines:
VMS Hunt Delay
Dial #506
Release 2.0 and earlier:
Dial 1=Immediate
2=Delayed
Release 3.0 and later:
Dial 1=Day
2=Night
Dial line number
Dial 0-6
The delay for extensions is:
VMS Cover Rings
Dial #321
Dial one digit (1-9) for the # of rings
before the call is sent to the voice messaging
3 is default
Jul 22, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
the display should say system programming
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Feb 03, 2009 | AT&T Lucent MLS-12D Phone
Service was connected on Saturday 10/11, telephone rings in your ear when phone number is dialed, telephone not ringing inside the home.
If the caller hears ringing after dialing the home but the not ring inside home. That means the number is active but the wiring inside home is faulty/ not properly connected. A phone rings /or works of a basic system. Two wires usually red/green as primary. If either one is broken or improperly connected the phone inside will not ring. That doesn't indicate a short. If it was a short the caller would not hear ringing at all. So the first thing you must do is the track the cause. Make sure home phone is plugged securely into phonejack. Still no dial tone check all other jacks inside home. If still no dial tone. Contact your service provider. They will need to send a technician to check the Demarcation point. Which simply means the connection point where the service provider wires , meets the customers house wires. They just need to verify this connection
Oct 13, 2008 | Lands Phones
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
67 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
