Question about Hotpoint Ovens
Hi I have a Hot Point Built in Oven Model Number WE 220D-7 Serial Number EY164022 I turn the oven selector to 250 degrees and element gets red hot If I turn up the selector knob to 300 degrees and up the element shuts down- no longer red hot. Question: Is the the selector control that is no good or another part and can I get the part number? Thanks In adavance Rob
SOURCE: f-23 error code
this sounds like an overheat problem this unit has several fans that run at different speeds any one of which could be compromised you will need an engineer to sort out
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
barkencoa
  • 3463 Answers
SOURCE: Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Posted on Dec 12, 2008
SOURCE: Oven gets too hot
What can I do to make suremy too hot oven dosent burn or overcook all of my food. It is a freestanding Amana that is only 3yrs. old.
Posted on Dec 17, 2008
directcurent
  • 59 Answers
SOURCE: GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
Posted on Jan 21, 2009
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
Whirlpool oven will only get to 250 degrees, help
250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
Sep 24, 2015 | Whirlpool Ovens
Tricity double oven
Hi Les. We had a tower oven with three ovens! One oven we constantly used had the element distort, and it had to be replaced.
Most likely the element is on its way out. If you have a multimeter, you can check the voltage supplying the element.
You will need to find the make, model number, and maybe the serial number of the oven to progress.
The details may be inside the oven door or on the rear of the oven. Do a google search, and you should be able to find replacement elements, and a local supplier of original parts or aftermarket replacements.
Jan 29, 2014 | Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My GE built-in oven is not heating up right away. The oven and broiler elements do not get red hot even if turned up to 500 and/or broil. As a guess it doesn't exceed 300 degrees. This is only...
It could indeed be the elements that are the problem if the elements are bad generally you will see a section of it that looks different than the rest(kinda looks like textured stucco if bad) if that isn't the case the elements must be tested to see if the proper power is going to them, you could do that by TURNING OFF POWER AT THE CIRCUIT BREAKER unscrew the element from the back wall of oven and pull element out about 6 inches out, attach a voltage meter set to measure at least 240 volts ac to the two wires, turn on breaker set oven to back and check for 240 vac to element. If 240 vac at element replace element if 240 vac not present the thermostat,or selector switch is bad not providing the 240 vac to element
Good luck,i hope this helps
Gene
Jul 31, 2011 | GE Ovens
When I turn the oven to 400 degrees for instance the temperature doesn't go to 400 degrees and the top element is hot, not super hot and doesn't get red. It is a Whirlpool Gols, Acubake system. Model...
Hi
Thanks for using FixYa. This indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 14, 2010 | Whirlpool Ovens
My oven cooks too hot, about 75 degrees too
find an appliance parts outlet and give them the model number and tell them you need a new oven thermocouple,you maybe able to just replace the thermocouple,or you may need to replace both due to being connected together
Apr 14, 2010 | Ovens
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Ovens Logo
    102 people viewed this question
    Top Hotpoint Ovens Experts
    Jason Harris
    Jason Harris
    ashburton
     Fix Your Board
    Fix Your Board
    Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
