Question about Sony Playstation 3 (PS3) Console
Yellow light & shutdown - Sony Playstation 3 (PS3) Console
    Scholar:
  • 35 Answers
The best way to fix PS3 light turns yellow light and shutdown is to fix by yourself! Learn the PS3 fixing technique by using this product here :
PS3 Ultimate Fixing Guide
This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
Posted on Sep 03, 2010
My 1983 Monte Carlos fuse box labels are worn off. I need to know if I got all the fuses I need or if am missing fuses
1. 5 Amp (Tan) - Instrument panel lights and lights-on reminder
2. 20 Amp (Yellow) - Choke heater
3. 30 Amp - Circuit Breaker. Power windows and sunroof
4. 10 Amp (Red) - Electronic control module
5. 25 Amp (White) - Heater and air conditioning
6. 20 Amp (Yellow - Stop and hazard lights
7. 25 Amp (white) - Windshield wipers
8. 10 Amp (Red) - Radio and cruise control
9. 30 Amp - Circuit Breaker. - Power door locks, seats and rear window defogger
10. 20 Amp (Yellow) - Courtesy lights, key warning chime, power antenna, horns, cigar lighter and clock
11. 20 Amp (Yellow) - Turn signals and back-up lamps
12. 20 Amp (Yellow) - Parking, side marker, license plate and tail lamps
13. 10 Amp (Red) - Warning lamps and buzzers, trunk release, torque converter clutch and vehicleicon1.png
speed sensor
May 11, 2014 | Cars & Trucks
Words on fuse box diagram faded. whats the appropriate fuses?
Please review this article: Where's The Fuse?
speed sensor
14. Not Used
Jun 08, 2011 | 1983 Chevrolet Monte Carlo
Where are the fuses for blinkers
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
I hope this helps :)
May 16, 2011 | 2004 Jeep Grand Cherokee
Lost owners manual and was testing fuses at the junction box. do you have any info. as to what each fuse controls. i lost my dash controls ex. speedometer oil guage . its 1999 jeep cherokee ltd
Here is the diagram you were looking for, hope this helps :)
May 16, 2011 | 1999 Jeep Cherokee 4WD
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
Red flashing light 80gb 3-4yrs old
You basically got the YLOD or Yellow Light Of Death, its when u turn it on it will flash a yellow light first then beeps twice & flashes red, And u can fix that without sending it to Sony coz it will cost a lot more. So here's what u need: Heat Gun,liquid flux, Screw Drivers, Heat Sink Compound (white one), some thing that u can use to clean the system and just watch this video from part 1 to 6: http://www.youtube.com/watch?v=U70SgRDVc...
Fluxing Video: http://www.youtube.com/watch?v=MZRReDIHT...
I suggest that u should have someone help u to use the tools(if u dont know how to use it).
Ways to prevent YLOD comeback:
- Put the system in "VERTICAL STAND" so it saves space while "Increasing airflow for better heat management."
- Put the system into a place where "nothing is blocking the air vents."
- Turn it off when not in use(or turn on auto shutdown into 1 hour).
- Eject disc when "not" in use.
- Give it a break! don't use it the whole day, 10 hours is the maximum play time that i recommend coz the graphic chip might get too hot that it will cause the system to shutdown.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
What is the fuse box layout for 1986 Lincoln Town Car?
Here is a recap by fuse/CB:
1. 15 amp -Light Blue
2. 8.25 amp -CB
3. Not Usable
4. 15 amp -Light Blue
5. 15 amp -Light Blue
6. 20 amp -Yellow
7. 10 amp -Red
8. 15 amp -Light Blue
9. 30 amp -Light Green
10. Not Used
11. 20 amp -Yellow
12. 20 amp -CB
13. 5 amp -Tan
14. 20 amp -CB
15. 10 amp -Red
16. 20 amp -Yellow
17. 15 amp -Light Blue
18. 10 amp -Red
Do you have a problem with a specific device? Let me know and I may be able to tell you what Fuse/CB.
Jul 23, 2010 | 1986 Lincoln Town Car
I need a copy of the fuse box underneath the dashboard of a 2004 jeep grand cherokee lorado limited edition
Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
F1 -- -- Spare
F2 -- -- Spare
F13 -- -- Spare
C3 -- -- Spare
Mar 07, 2010 | Car Audio & Video
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Sony Playstation 3 (PS3) Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
