'SHARP LC 26SH12U' & Philps DVP 5160
Help!
Connected new DVD player to new TV and the picture is in black and white. Cannot figure out how to get colour from looking very closely at both manuals. Please advise!
Thank you
  • mweness Feb 23, 2009
    I have a sharp lc-32p50e and I get a black and white picture when I use the first scart connection socket for anything I plug in. Picture is normal when I connect on the second scart socket. First time I have needed to use both so not sure when the problem began.
Sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
Posted on May 27, 2008
Why is there no color
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur. Also check the color settings on the DVD player under picture mode.
Ref: http://www.docs.sony.com/release/DVPSR200P_US_ES.pdf
Dec 18, 2012 | Sony DVP-SR200P DVD Player
Since disconnecting my Sony DVD player it now only plays in black and white. It is relatively old model DVP-NS51P. I have successfully connected an alternative DVD player to the same TV so it cannot be a...
Make sure that the TV system that the DVD is outputting is NTSC, Press SYSTEM button on the remote control (is there's such button) or change the system in the DVD's menu.
Nov 09, 2010 | Sony DVP-NS51P DVD Player
When connected to my TV there is no color but there is color on the Player?
If you are saying that when your DVP player is connected to the TV, it is showing black and white, then you might need to press the NTSC/PAL button on your DVD's remote control. Press that button until color comes back.
Oct 05, 2009 | Sony DVP-FX930 Portable DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Televison & Video Logo
362 people viewed this question
Top Televison & Video Experts
