Question about Home Fencing
I have a sears 50188 3ton floor jack that is leaking. Do they make a seal kit?
  • 4,102 Answers
Hi, they dont make seal kits for jacks but one thing you can do is if you take the seal out it will either be a rubber o ring type or copper ring type take this out then go to a car spares shop and buy the same type of o ring doing this will solve your problem, most parts in these you can buy off the shelf so take the seal out and go to a car spares shop or hardware store and ask them to match one up for you, make sure its the exact same size etc and you should find this will stop the leak and fix your problem.
let me know if you need further assistance ok
Posted on Aug 23, 2010
How can i fix a floor jack it does not go up
that depends did it leak oil out of the shaft seal ? if it did you could add more oil to resavor but that would not be safe as oil will continue to leak out seal and jack will fall down , Most auto parts stores sell hyd jack oil in a can
Sep 22, 2014 | Cars & Trucks
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Sears 11/2 ton floor jack
Is there anywhere that you can tighten the seal retainer if not needs a new seal . My experience is that a seal kit is as expensive as buying a new jack plus the work that goes into it. Look up how much to buy a new one and a set of seals then decide
Oct 21, 2013 | Washing Machines
Transmission seal is leaking. It appears
To replace the front seal, it's a bit involved and you'll need the proper equipment and tools: Floor jack, transmission floor jack, jack stands to get the truck elevated enough to pull the tranny.
IF it's an automatic, you'll have to take the bellhousing loose from the motor, driveshaft(s) out, remove tranny and torque converter, all lines, linkages, drain oil.
If you don't have much mechanical experience, you may want to have someone else tackle it for you. It's doable, but it's a bit of work.
If you're going to attempt the repair, I would recommend purchasing a repair manual such as a Haynes, or possibly a CD service manual. The step by step instrucitons would get you through the job, plus you'd have access to oil and torque specs to do the job correctly.
ps: if this is the REAR seal, it's a simple job of dropping the driveshaft and replacing the seal.
k
Jun 29, 2009 | 1991 Ford Ranger Supercab
Jacks stalls 1/2 way up
try opening the hydrolic oil "fill" plug to let air in...Your jack came with a vented plug,for you to put on after shipping...so oil doesn't leak while being transported...I hope this helps,...1nglen
May 04, 2009 | Plumbing
Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Apr 02, 2009 | Plumbing
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Home Fencing Logo
416 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
