Question about Brother DCP-385C Stylish Colour Inkjet Multifunction Printer
Dear Sirs, I have a brother DCP-385C printer. Last week the black ink ran out on the printer. So I went and purchased the correct ink (LC1100BK)to replace the ink. I have installed the ink cartridge correctly (removing the yellow plastic cover etc..)and have ran the cleaning option on the printer itself on a few occasions. Still I have no luck in getting the printer to print. I would be very grateful for any assistance you could provide in helping me to fix this issue. Kind Regards, Barry Whelan
  • 1 more comment
  • barrywhelan1 Aug 23, 2010
    Hi Steve!
    thanks for your advice.
    I have just tried the above what you suggested twice, but still no luck.
    Any other ideas what might be causing this?
    I will try this method one more time again though just incase.
    Hi Steve,
    I tried what you suggested on a couple of occasions now.
    I put a drop of water the the hole and no luck after I let the printer do its job cleaning the print heads.
    any other ideas on how to fix this?
    Regards,
    Barry
    Dear Sirs,
    I posted this question on a printer earlier today.
    Still have no luck fixing the problem however.
    Here is the question:http://www.fixya.com/ThreadAskerGS.aspx?...
    I would be grateful for any advice anyone can offer on the subject.
    Please be advised the printer is about 6 months old, and I have not got the receipt.
    Kind Regards,
    Barry
  • 1,675 Answers
Hi Barry i find the best way to sort these things out is, to remove the new ink cartridge get a slightly damp cloth, and tap the cartridge till you get some ink on the cloth, then ( this might sound strange ) drop a blob of water into the hole of the cartridge not allot just one little drip then replace it in the printer then do a clean cycle, i have had a 90% success rate at doing this, most of the time all it is , is an air block between the cartridge and the print head, and normally this resolves the problem, make sure you do not put allot of water in the hole just a little blob...hope this helps please vote and rate thanks
Posted on Aug 23, 2010
  • 1 more comment
  • steve morris
    steve morris Aug 26, 2010
    hi barry
    you could try purchasing a black ink refill kit, and injecting some ink into the hole this is normally caused by an air block, you could also, just dab a bit of black ink onto the print head while the cartridge is out as well, see if it seeps through, the actual print head could be blocked with dry ink, just use the syringe from the kit to put some in, it will come out messy on the paper for a while till the ink makes its way through the print head...hope this helps
  • barrywhelan1 Aug 27, 2010
    Thanks Steve, will try getting a black ink refill kit to see if it helps.
    thanks for your help! will keep you posted
  • dean00007
    dean00007 Apr 18, 2012
    Thanks very much Steve Morris I did the above and it worked cheers mate Dean Monaghan
  • 3,083 Answers
Sometimes the ink cartridges get a bit dried out. You can take a soft cloth and isopropyl alcohol and dab the cartridge head, trying to soften the dried ink, and allow it to flow.
On some printers, there are key sequences you can do to try to reset any software that can be "jammed", but I couldn't find any info on the net. You might contact Brother and see if they can give you a key sequence to reset the printer, or know of another way of helping you. Here is Brother's support website:
http://www.brother-usa.com/support/
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 24, 2010
I keep doing tests and cleaning, replaced black but not coming through . brother DCP385c
You will need to have the print head replaced. Try calling 1-877-brother, they are covering the cost to repair this common problem.
Aug 04, 2011 | Brother DCP-385C Stylish Colour Inkjet...
What can I do with my printer, it will not print black? Brother DCP - 385C
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother DCP-385C Stylish Colour Inkjet...
The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
In which case you need to return it and get a replacement.
Mar 07, 2010 | Brother DCP-385C Stylish Colour Inkjet...
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Brother DCP-385C is not printing the menu on the printer is telling me unable to init.70
That error code tells us that the cleaning assembly can't move up and down properly. You need to unplug machine when the carriage is in the center, look over on the right side where the printhead parks to see if there is a paper scrap, clip, or something there stopping the cleaning unit.
Jun 25, 2009 | Brother DCP-385C Stylish Colour Inkjet...
Brother DCP-385C Stylish Colour Inkjet Multifunction Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
