Question about Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER
I'm located in Baton Rouge, LA and have owned my Master Temp 400 heater is 2 years old and has been working perfectly until recently. After a recent thunder storm, my fan has come on and will not shut off. There are no readings on the temperature display and none of the system operation indicator lights will come on.
  • 366 Answers
Try turning off the supply power at the breaker to reset the system. If that does not work, you may have had lightening damage to the circuit board.
Posted on Aug 23, 2010
Hello can you help me locate the front power windows fuse
Lucy, locate the front power windows fuse, it is shown in your vehicles manual or Re POST year, make, model,engine, transmission and complete question so we, here at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
how to check window motor fuse
AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics...
Interior Fuse Box Location 2009 2012 Chevrolet Traverse 2009 Chevrolet...
power window fuse location Google Search
Aug 27, 2016 | Cars & Trucks
2002 Noah. Where is fuel filter located?
normally in tank attached to fuel pump assembly. Filter is a fuel inlet strainer. link is not your vehicle but shows the basic electric fuel pump assembly with attached filter(strainer)
press the helpful button
AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics What...
Jan 22, 2016 | Toyota Cars & Trucks
What would be the best way to get to phoenix AZ from baton rouge la by bus
This is a example if you were leaving on the 18th of this month also I listed the amenities and the total time of trip.
Wi-Fi
Air Conditioning
Power Outlets Departure
Wed, March 18, 10:55 AM
Baton Rouge Greyhound Station
1253 Florida Blvd Arrival
Thu, March 19, 1:55 PM
Phoenix Greyhound Station
2115 E Buckeye Rd
Trip duration
1d 3h 0m
Mar 18, 2015 | Cars & Trucks
Power windows not working
"It is not likely that a fuse or relay will cause a single window to not roll up or down. More likely, the power window motor, door switch or window regulator has failed." AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics...
Mar 03, 2015 | Cars & Trucks
2001 Jeep Grand Cherokee Laredo. Left Brake light works when running or headlights are off. But when I turn them on the left brake light sometimes works, sometimes doesn't. How do I fix this.
You probably have a bad ground connection somewhere. The brake light current is returning through the other lights [probably running lights] until you turn on the lights and the +12v is on both sides of the filament.
If the vehicle has had recent body work, take it back to the body shop and make them fix it.
Otherwise, look for the wiring going to the brake lights and follow it back to where a ground wire is [supposed to be] fastened to the metal chassis. It could be rust causing a bad connection.
If the turn signal and brake lights share the same filament, it could be in the turn signal switch.
AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics How To...
Feb 05, 2015 | Jeep 2001 Grand Cherokee Laredo
I reside in Baton Rouge, LA...Where is my nearest "Toro Service Center" to get my lawnmower repaired?
HIGHLAND HARDWARE 7460 HIGHLAND RD, BATON ROUGE, LA, US, 70808 Phone: (225) 766-3049, Fax :(225) 767-5747 Services Toro products regardless of where purchased.
Sep 10, 2010 | Toro Lawn Mower With Toro Power Tools
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Logo
144 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
