Question about Moulinex DG6 Food Processor
I have a Robot Coupe SA food processor, model RC3600, 120 volt, 60 hz, 6.5 amp, serial number R1949066. (circa 1980) I need to replace the food bowl. The spring loaded mechanism in the handle of the bowl broke; this controls the mechanism to lock the bowl to the base motor. Can you tell me if a replacement bowl is available and where I might order it. Thank you, Alma Reinke, e-mail andreinke@aol.com
4 Suggested Answers
SOURCE: Broken processing bowl to food processor
I have replacement parts available for the Technque CETOFP263, will only charge nominal fee plus shipping costs. email me or post to ebay seller churkey123.
Posted on Mar 16, 2009
  • 81 Answers
SOURCE: how do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Posted on Jul 25, 2009
  • 81 Answers
SOURCE: How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. capt_rick1912@yahoo.com
How to remove and install on/off pin for robot coupe r2
Thanks so much for the advice. Any idea what size TORX is required?
Jan 08, 2012 | Robot Coupe R2Dice Ultra Food Processor
Remove pin & replace in work bowl
it takes two to do this. there are two holes on the bottom part of handle. find something strong to push them in. one person pushes them in and have other person with pliers pull on the plug that you need to remove to get to broken pin. after that...replacement is easy
May 14, 2011 | Robot Coupe R2U Ultra Food Processor
We have a r6n processor. The part that goes on to the base is twisted and won't move in either way. The locking pin is there but cannot be used. It is almost as though it is cross-threaded. What do we do...
Was your product purchased in the USA? I did not find your model number listed on the Robot Coupe website:
http://www.robotcoupeusa.com/
You may be able to find a parts diagram for a similar machine that might assist in understanding the assembly and how to take apart. Unfortunately you need to have an account which would be established when you registered your machine. Other option is to use the search function and find a local service dealer:
http://www.robotcoupeusa.com/support/
Feb 15, 2011 | Robot Coupe R6N Food Processor
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
Jun 26, 2010 | Robot Coupe CL50 Food Processor
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
I lost the shrreder & slicer.Can I replace it on my FP1510.
I have a Robot Chef RC3 228/248 volts and need a new food bowl and lid plus shredder. Can you help judybrittain@gmail.com
Nov 11, 2009 | Black & Decker FP1510 Food Processor
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
Robo coupe CL52D would not turn on
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. capt_rick1912@yahoo.com
Dec 16, 2008 | Robot Coupe CL52D Food Processor
Cindy,
Nov 02, 2007 | Robot Coupe R2U Ultra Food Processor
Moulinex DG6 Food Processor Logo
74 people viewed this question
Top Moulinex Food Processors Experts
clay_pots_47
clay_pots_47
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
