Question about Garden
Swisher 60 inch pull behind has charged battery, good fuse but will not engage starter with ignition switch on through key starter
  • 2,272 Answers
TEST #1Using a remote starter switch or a suitable device, make a connection between the large terminals on the solenoid. If engine does notcrank!!!•Battery may be weak or dead•Starter may be bad•Battery cables may have bad connections•
Do notgo to Test #2 until this test gives results.
If engine did crank in test #1, disconnect green wire at spade connector and apply positive voltage from the battery to the yellow wire with the orange stripe. The positive voltage can also be picked up on the solenoid terminal where the fuse connects. Make sure the green and black wire with the eyelet is well grounded. If engine doesn’t crank now, replace the solenoid.Remember, all other tests are useless unless these two tests make the engine turn over.
TEST #3:----
If engine did crank in the first part of test #2, reconnect green wire to solenoid. Using a jumper wire attached to the positive terminal of the battery, apply 12 volts to the red wire on terminal B of the ignition switch. Try to crank, using the ignition switch. If engine cranks, the fuse or the fuse holder, or related wiring is defective somewhere back to the solenoid.
TEST #4:--If engine did notcrank in test #3, this time move the jumper wire attached to the positive terminal of the battery, to the green wire on S terminal of the ignition switch. Ignition switch does have to be activated for this test. If engine cranks now, ignition switch needs replacing.
The other possibilities can be faulty PTO switch or the faulty CLUTCH.
Apply 12 Volts to this terminal. Clutch should activate, if it doesn’t, clutch is defective.If clutch checks OK, use a voltmeter to measure for 12 volts at the brown wire’s terminal. First turn ignition switch to the ONposition but don’t start the engine. Now engage the PTO switch. For the first test put the negative probe on a good ground, noton the white wire’s terminal in the plug. If no voltage is measured, move on to next test.-------The problem may be a poor ground on the white wire in the clutch plug. Check by testing for continuity to ground or check for voltage between the two terminals. If no voltage is measured, move on to next test.--------Some of our clutches have a different receptacle for the wiring harness, but the testing is the same. The white wire is always the negative terminal and the brown wire is the positive.----------With the PTO switch ONthere should be continuity between these two connectors, if not, replace switch. If switch tested good, check wires and connectors back to ignition switch and back to clutch plug.:-------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 23, 2010
2001s10 starter won't engage makes no noise everything else works changed the ignitions switch could it be the neutral switch . I you play with the key sometimes it well start
I looked at info for the v6.
Two voltage circuits at starter motor. One comes from the battery, hot all the time. The other goes hot with key in crank position and is wired through neutral switch, then comes the starter relay. Use a test light to check for voltage. The starter motor grounds through engine block. Any testing, make sure tranny is in park or neutral and parking brake is set. There are fuses involved, not only check fuses, check voltage on fuse circuits. Make sure battery has a full charge and battery connections all good.
Nov 27, 2016 | Cars & Trucks
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
Swisherinc com
If you leave this mower out in the weather you might have a wet ignition system. Clean battery, dry out switch (contact cleaner), inner locks and ignition parts. Do not jump the fuse to try to start.
Oct 22, 2013 | Swisher 60" 27 HP Zero Turn Lawn Mower -...
Adjust belt tension and brake linkage on Swisher 44 in 11.5 HP mower
is the belt tension adjustment on the lever that engages the blades?
Mar 29, 2013 | Swisher Garden
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
No start, no noises when key engages the start position.
The large red wire at the starter is to the battery. The smaller wire is hot in the start position only! have someone turn the key to start and then check for voltage. If you have voltage you need a starter. If there is no voltage you either have an open from the ignition switch or a bad switch on the column. 1 last thing. Most cars have a fusible link at the starter. If there is a short somewhere the wire acts like a fuse and blows. You can check that by pulling in the wire or just feeling for a spot with no wire.
Jul 21, 2012 | 2000 Chrysler Sebring
I pulled the starter,alternator & battery they all checked good and ity still wont turn over what could it be?
If you can hear the starter click or engage when you try to start . Either the battery has low voltage or the engine has seized. You can check the engine by putting a wrench on the crank pulley bolt and try to turn by hand.Make sure to disconnect the battery first. If the engine turns it's good. If the starter is making a loud grinding noise but does'nt turn the engine. It's your flywheel/flexplate. Also make sure your battery connections are clean and tight for proper voltage delivery. I'm not sure if your car would have a fuse or power relay for the starter,but it might be worth checking out. If you do not hear a click from the starter when you turn the key it could be a short in the ignition switch.Not the key tumbler,the electrical switch is behind the ignition key tumbler. Hope this helps. Other than this you may need a repair manual to trace the wiring of the starting system and fusable links.
Jul 25, 2011 | 1994 Oldsmobile Cutlass Ciera
Smaller belt on my swisher pull behind mower keeps breaking
make sure it's not coming into contact with any sharp surfaces
Jun 26, 2010 | Swisher T14560 T - 60" Trailmower with 14...
My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
May 03, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
