Question about Encon Industries (78018) Ceiling Fan
We have one of your fans, Model No. 6EB52PB5, installed in May, 2000. You folks sent it to replace a Model No. 5EMR52PBE that developed a whum-whum noise at slow speed. We purchased that fan in August, 1999. Now, the replacement fan has developed the same noise. Is there some fix or repair that I can handle to correct the problem or do we need a new fan? Earl Gates 1820 N. Drew St. Appleton, WI 54911-2928 920.830.2419 fiberwords@sbcglobal.net
2 Suggested Answers
  • 69 Answers
SOURCE: Model H52 hugger ceiling fan.
If you replaced the speed switch with a dimmer control or a lighting control device it will not work properly. You specifically require a fan control switch.
Posted on Sep 23, 2009
The orginal part # is 697853 the replacement part sent is 796201. my motor doesn't have a bolt hole in the bolt on top of the flywheel. do I remove the bolt completely to install the new flywheel fan?
that is the wrong part sent. its for a different model, ask for the part number you ordered. its not compatible, its even a different size. not by much but still different.
Jun 29, 2017 | Cars & Trucks
Hunter fan
Good... reasonably priced fan.
Be sure to follow codes for securing over-HEAD-support.
Lots of folks have been injured because "installers"...
merely remove light fixture.. and install FAN WITHOUT
proper support...
VERY Dangerous (hard hat area (at best))...!!!
Nuff said?
An exquisite source and nationally recognized FAN AUTHORITY... THE FAN MAN
Fan Man Ceiling Fans and Lighting
Jul 06, 2016 | Hunter Dryers
I have a 2001 merury villager estate and the heater fan isn't working. Heat works fine but the fan won't come on. What do i need to do to fix it?
Charlie, 1st thing is to check your fuses. I will post some links to help you see and solve problem. May not be your exact model but steps are basically the same.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Install Replace Heater AC Fan Speed Resistor Ford Taurus Mercury...
How To Install Replace Heater AC Blower Fan Motor 2004 08 Ford F150
How To Install Replace Heater AC Blower Fan Motor 2000 07 Ford Focus
Feb 27, 2016 | Cars & Trucks
My ricoh MP 2000 is printing blank documents when a print job is sent
is the copying ok? if yes then reload the print driver .it is causing the problem.if copying is also blankthen check the processing unit. the charge roller might be facing some problem or the developer gears might be worn out .
Sep 28, 2011 | Ricoh Aficio MP 2000 Black and White...
I appreciate the "help", folks.
yep for sure, see my previous response. if you have a twin fan model, i can almost guarantee you it will be a failed fan capacitor... Especially if its a Daikin or LG... Good luck
Jul 16, 2011 | Heating & Cooling
I need help on how to replace a ford 99 model super cab fan belt and what size belt would I need... also can I tighten the head gasket with a shifter.. cluless? ? Thank you. Carryn
First to get right fan belt you tell folks at parts store year, make & model & engine size and they look it up for you. To change belt depending in which belt you have to loosen alternator, power steering pump etc... bolts and slop old belt off new one on and retighten. (Parts folks can show you how also) If you have a bad head gasket, they need to be replaced not tightened.
Mar 31, 2011 | Ford Ranger Cars & Trucks
Greeting folk i own a 1988 Honda Prelude I have
see if you can get a chelton manuel at AutoZone this well help you out alot.
Jul 22, 2010 | Cars & Trucks
We need to replace the drum unit on a Minolta Di3510 and were told that when you replace the drum unit you also need to replace the developer. Where and how is the developer replaced on this unit.
Not familiar with your model.... but...
When you install the toner cartridge, the toner is routed into a developer unit. this unit has "developer" in it that mixes with the toner. Generally you purchase the developer, remove the developer unit, remove the top cover of the unit, empty the contents of the unit. add the new deveoper to the unit, replace the cover, install the toner cartridge. a lot of times this requires going into service mode to reset the developer count and run a conditioning mode. Not sure if this is any help but here you go.
May 18, 2009 | Office Equipment & Supplies
Cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Jul 30, 2008 | 2000 Pontiac Grand Prix
Encon Industries (78018) Ceiling Fan Logo
24 people viewed this question
Top Encon Industries Dryers Experts
Dan Webster
Dan Webster
Are you an Encon Industries Dryer Expert? Answer questions, earn points and help others
