Question about Ovens
We have a Cookworks MM55502SS electric oven. As far as we can tell there are two oven settings ? fan and fan adjusted. On the fan setting, the fan blows but there?s no heat, no matter what temperature we set the oven to, so we can?t cook with this setting. We?ve been using the fan adjusted setting instead, but that doesn?t seem to be heating up as much as it should. We?re having to add on half an hour extra or more to cooking times, and struggling to cook meat through thoroughly without ruining it. Is this a known problem, and does it require a repair or replacing the oven? We don't have a manual for the oven (we moved into our flat recently and the oven was already installed).
  • 1462 Answers
SOURCE: Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
Posted on May 18, 2007
  • 236 Answers
SOURCE: Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Posted on Jun 25, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
  • 6 Answers
SOURCE: When using cook timer will the oven shut off after the set time?
no are you thick its a gas oven
Posted on Apr 15, 2009
Hotpoint de47x/2
These ovens often use methods of regulating the fan voltage or current limitors inside the motor itself , to test this it requires a fair knowledge of electrical motors as there are several types used in fan housings, not knowing this model I can only give you a General guide
Let me know your competance level as far as electrical testing is concerned. As the danger of electric shock from a a/c or d/c motor is quite considerable.
Nov 13, 2013 | Hotpoint Ovens
Fan is not turning
yes if you ave is set for fan forced...no if you have is set for non fan force....a lot of ovens have many setting depending what you are cooking....top oven/bottom oven or fan oven plus a combination.
Jul 24, 2010 | Frigidaire FEB30S5D Electric Single Oven
My oven will not stop at the assigned temp.
How much is it off? Adjustable with the thermostat knob. If too far for the knob setting then the thermostat is bad.
Eric
Sep 14, 2009 | Whirlpool RBD275PD Electric Double Oven
I need a user manual for the cookworks signiture s/steel electric fan oven , but cannot find one ???? can anyone help cheers dan,,,
Hi there, after days of searching the web, I finally FOUND a site with the user manuals for Cookworks Breadmaker models:
http://manualfox.com/link/cookworks.htm
If anybody is interested in the XBM1138 manual - I purchased this there.
Diane
Jul 01, 2009 | Cadco Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Ovens Logo
106 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
