Question about Canon Rebel XT / EOS 350D Digital Camera
Dark exposures why do i constantly get dark exposures?
  • LWoo May 28, 2008
    I really believe there IS something wrong with my camera. I know how to set the exposure and speed. I have tried all the settings, from AUTO to AV and tested in all sort of lights. I pay attention to the camera's readings before I shoot a picture and I make sure it reads a proper exposure.
    Yet, I can take a picture outdoors with the bright sun shining on the subject, with the camera set at f1.8 and ISO 100 and when the picture is taken I look in the viewfinder and looks like a great picture, but once I downloaded and view it in the computer it is DARK, and I mean very very underexposed! It makes no sense at all. I am trying to shoot as wide open as possible and trying to purposely overexpose a picture, and it will still be underexposed!
    I do not believe any setting on my camera to be the problem (in case y'all are thinking of the exposure compensation, that is at 0) but maybe I'm missing something.
    Could something in the camera be broken? maybe something in the light meter sensor?
  • 111 Answers
This could be many things. If indoors, use higher iso setting and/or use the flash. Make sure exposure compensation is set to 0, or raise it. Use one of the automatic programs and let camera pick shutter speed and aperture. In manual mode, pay attention to exposure value in viewfinder, and avoid using higher apertures unless outdoors in bright sun (f16, f22, etc) the higher this number the less light is allowed to camera.
Posted on May 15, 2008
Canon Ixus 95. When taking pictures of people with dark clothes, the face and background (a stone wall in this case) become white and undefined. Is there a solution?
Sounds like your camera is exposing for the dark clothes and over-exposing the face. You could set the "exposure compensation" down a notch or two in this case for a better exposure.
Nov 15, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Dark Pictures
try reseting the camera back to default settings, there should be a function for that in the menus or a small reset hole somewhere in the camera.
Jul 23, 2008 | Canon PowerShot A640 Digital Camera
My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Jan 03, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
Visit www.kodak.com/go/stepbystep
NOTE:
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Sony TRV308 Camcorder is not picking up light when recording
Hi there and welcome to FixYa.
Do your videos come out dark when you play them back? Or Is it dark while you are recording?
If it's dark while you are recording, is it dark in the viewfinder, or the LCD screen?
If your videos come out dark when you play them back, check the manual exposure. Hit the exposure button and turn the sel/push execute wheel to change the exposure to lighter.
If you are looking through the view finder to record and it's dark, check to make sure the window is clean.
If your LCD screen looks dark while your recording, put the power switch to player, hit the menu button and scroll down to LCD, select it and turn the select wheel to brighter.
I had to guess at what your problem was due to the information you provided, so I tried to cover the most obvious. If I failed to answer your question, please comment and be more specific.
Hope this helps, and thank you for coming to FixYa.
Rob
Mar 20, 2009 | Sony Video Cameras
Camera Flash & Picture
I just got this camera for Christmas the only way that I know of how to fix it is to change the exposure manually. If the picture is to bright you need a negative exposure, if it is to dark you need a positive exposure. I have noticed that the auto exposure does not get the correct setting that you need for the lighting.
Oct 11, 2007 | Polaroid A500 Digital Camera
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
