There is a pink line on top of my laptop screen and the screen also shakes sometimes and white flickering is also there . plzz suggest some solution ....
    Master:
    Sergeant:
  • 460 Answers
Your laptop screen has been damaged. Pls check it from service center.
Posted on Aug 23, 2010
  • pankaj90chha Aug 23, 2010
    r u sure its not a software problem ???
Toshiba Mini NB205-N230 screen Flickers and becomes Unusable
Either the cable that runs from the screen tot he motherboard is loose/broken or your video chipset on the motherboard has dry solder joints.
Mar 10, 2012 | Toshiba Mini NB205-N230 N325BL WH BN PK 10...
Laptop screen suddenly starts flickering with warious color bars
If your lcd screen got harizotal line ( Pink, blue or red ) and flickering, that means your lcd ribbon or board on back top was crack or faulty I believe your lcd screen model is LG Display. There are not have any way to repair it. You must be replace with another lcd but I suggest you to change it with Samsung brand lcd screen. You can buy new lcd screen from ebay.com
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Toshiba Computers & Internet
Asus x83v monitor has a red flickering bar across the lower part of the lcd it is as thick as the task bar thats why i have to place the task bar on the top, its like a static flickering red to pink and...
The display hardware is damaged. Most likely you will need to replace your screen. In rare instances, this can be caused by a loose ribbon connector from the display to the display adapter board.
Mar 29, 2010 | ASUS X83Vm-X1 Notebook
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
