Question about Toro Garden
I have a toro wheel horse classic 312-hydro. Sometimes when you turn the key nothing. It always ends up starting though. It might take a while but it aways starts. When is does turn over it starts just fine ans right away. I have a new battery and have cleaned all the connections from the battery to all the wires from it. Any ideas as to why it will not fire ?
Just purchased 1995 says seller, serial # says 1990, 312h kohler wheelhorse 157 hours, royaly maintained, new condition runs great when it starts,turns over great, spins fires spins fires over and over then back fires thru carb, flames this no start, help going to snow tonight
Posted on Feb 26, 2011
I need a manual for toro wheel horse 268 hydro model 72107 serial no.210000417
Go to TORO.com and look for manuals. They are available for download
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jan 23, 2017 | Toro Garden
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Nov 12, 2013 | Toro Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
Need to locate manual for wheel horse 520-HC Garden Tractor, 1988
Go here and put in your Model and serial number of the tag under the seat and you can dowload a Owners Manual. https://lookup3.toro.com/request/request.cfm
Dec 08, 2011 | Garden
My toro wheel horse tractors & riding mower 31-12K801 312-8 keeps backfiring when I am mowing the lawn and stops and will not turn back on until you let it set for awhile. I had replaced the spark ...
I had a mower with exactly this behavior. Mine had a 14 HP Kohler Engine. After considerable frustration, we replaced the electronic ignition module, and it has worked perfectly since then.
Aug 17, 2010 | Sport & Outdoor - Others
TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
994 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
