Question about Avaya Corded Phone avaparp18d
CALLS NOT ROLLING OVER TO ADDITIONAL LINES - Avaya Corded Phone avaparp18d
The phone company controls the "HUnt".
If line 1 is busy and will not roll over to line 2, then it is the phone company....
Posted on Aug 23, 2010
Mitsubishi model WD-52525 purple lines across screen
Rolling lines are color bars that scroll from the top of the screen to the bottom and generally represent a malfunction of one or more raster patterns. The TV picture is made up of scanning lines; however yours has an additional color line moving in between the normal synchronization process. Various electronic elements such as resistors, capacitors, diodes, and resistors, may change in value over time. Changes can make various electronic functions change from a normal routine to an abnormal routine such as you are seeing on the TV. If the problem is too difficult to put up with, you can have the mainboard or video RGB projection tubes replaced if found defective by a professional technician. Other than that, you cannot fix the problem yourself.
Dec 25, 2013 | Sony KP-57WS500 57" Rear Projection...
How do i stop the panasonic KX-TGA641 from rolling calls to my cell phone
You apparently have call-forwarding activated. The exact procedure for deactivating it may vary by company, but in most cases you simply dial *73 on your phone (the Panasonic, not your cell). Contact your telephone company (the landline) for exact instructions.
Apr 24, 2012 | Panasonic KX-TGA641T DECT 6.0 ADDITIONAL...
Clear picture, but rolling lines
it might be due to bad signal strength. check for it. good luck!
Oct 14, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
I have installed an 8 port slt card and cannot get the extensions to dial out. Can receive incomming but not make internal or external calls
If you installed the 208 or 308 extension card, you also added 2 or 3 extra C.O. lines. When you dial "9" you are accessing lines that don't exist (the new highest lines).
Go into system programming and choose option 3.3 or program 400 and disable the additional lines.
Carl
Oct 07, 2009 | Panasonic KX-TA824PK Phone
I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
Apr 10, 2009 | Panasonic KX-TA824PK Phone
Lines on top of screen
Hi and welcome to FixYa,
Initially, sounds like a capacitor at the vertical section about to fail, leaking or blistered. Additionally, have seen some of these models suffers from vertical fault due to a defective capacitor in the power supply section or cold solder.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 03, 2008 | Televison & Video
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Avaya Corded Phone avaparp18d Logo
182 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
