Question about Music
Faulty connection for AC power adapter on an 8 month old yamaha digital keyboard psr-e413
    President:
  • 1,138 Answers
If the adapter is faulty I recommend replacing it with the exact one for your keyboard. Any Yamaha music dealer should have one. If it is the jack in the keyboard that the adapter plugs into that is faulty it can be fixed. It is soldered to the circuit board and the solder joint has likely failed. You will have to carefully disassemble the case and maybe take the circuit board out if the solder side isn't accessible. Once you can see the solder joint wiggle the jack to see where the break is. You will need to resolder it. If the jack is broken ( the center pin in the jack sometimes breaks) you will have to desolder it and take it to a good electronics store to obtain the correct replacement and then solder it in.
Posted on Aug 24, 2010
Testimonial: "Thank you so much for taking the time to comment- you were absolutely right! "
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
No power to the switch but will power up with batteries
One of two most common possibilities are a non-functioning AC adapter or keyboard AC adapter connector next to the Power On Switch has a cold solder joint and does not pass voltage.
Nov 04, 2013 | Yamaha PSR-E413 Portable Keyboard
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Sep 30, 2013 | Yamaha PSR-E413 Portable Keyboard
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Music Logo
181 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
