Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier throught the wall a/c and heater unit. When you turn it on, the compressor buzzes for a few seconds and then goes off. The heater nor the fan motor comes on either. Any ideas on where to start?
  • 674 Answers
Start by making sure its getting the right voltage (line and load side of the contactor) then check the capacitor/s. Let me know what you find so I can go further if I need to.
Posted on Aug 23, 2010
Just replaced the capacitor, and reconnected. Turned power on and heard a buzzing sound from the condensor, then the fan turned on. the unit only runs for a few minutes then shuts off
The buzz is the compressor failing to start.The blue or purple wire from the compressor goes to herm on the capacitor. If it's wired right and does not stare the compressor is bad.
Jun 23, 2014 | Bryant 2 Ton 17 Seer Air Conditioning...
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Carrier High Efficiency Weather Maker 38TZA024320 8 summers No Cold air controls are working the fan turns on when the compressor tries to start you here a short buzz repeats every couple seconds over the...
Hello
It would be worth a try to put a new start capacitor on.Also check the compressor contactor for burt or pitted contacts and replace if needed.
If this is a three phase unit be sure you dont a one blown fuse in the disconnect box.
Aug 03, 2011 | Carrier Heating & Cooling
My carrier 38ckc036350 is 6 years old. Today the compressor stopped working. The fan outside comes on and every few min i hear an electrical buzz like the compressor is trying to be energized. Are there...
Hi!
It sounds like the capacitor and/or compressor are quitting. Try getting a Start Capacitor of the same uF (I think 35 uF for Commpressor and 5 uF for fan motor) as the one you have, OR get a Start Kit from any AC parts shop for about $10 and hook it up in line with the old capacitor, if you have a two terminal capacitor plug the terminals one, on each end, if you have a 3 terminal called DUAL Capacitor, each terminal is stamped with the words FAN, HERM and the letter C for common, one lead goes in the C terminal and the other one goes on the HERM.
Install it and turn unit ON. Good Luck!! Don't forget to rate this post!!
Aug 20, 2010 | Carrier 38CKC036 Air Conditioner
There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Jan 06, 2010 | Mitsubishi Heating & Cooling
Carrier AC 38CKC019 may have overheated. The fan unit buzzes but does not turn.
Hey there, ok, now if the fan is spinning and the compressor is buzzing, the compressor is locked up and needs to be replaced. If neither is running and the buzzing is coming from the control panel on the unit, it could be the contactor. Also there is a chance that the fan motor burned up, causing the compressor to fail so the fan would be off but the compressor is buzzing and locked up. If nothing is running also check the circuit breaker it could just be he conactor you are hearing. At that point you need to figure out why the breaker tripped. Let me know what you find out
seth
Jun 25, 2009 | Carrier 38CKC018 Air Conditioner
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
37 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
