Question about Delta & Single Handle Shower Faucet
In my bathtub the water does not come out of the shower head anymore just the faucet. what do i do and how do i fix the problem.
    Problem Solver:
  • 6 Answers
There are two possible reasons for this problem.
The easiest to fix is calcium build up blocking the shower head. Remove the head and soak it in (for example) LimeAway or CLR, then rinse it and flush it out very well before reattaching it and, especially, before trying it out.
If this doesn't get results you likely have a problem with the washers in the diverter (that thing you pull to switch to shower). One of them may have deteriorated to the point where it worked its way into the shower line and is blocking it.
Are you willing and able to disassemble the plumbing to make the repair?
Posted on Aug 24, 2010
3 Suggested Answers
SOURCE: water only comes out shower head, won't come back
sounds like the diverter is jamed. it may be in the spout or a button in the escheuchon. if spout try to unjam the pull up knob or the pull down ring. if in the escheuchon remove part and replace.
Posted on Jul 12, 2009
motor1258
  • 6674 Answers
SOURCE: Ahhh... I bought an older
Normally the diverter in the spout does just that. It's basically just a little door you pull up to stop water from flowing out the outlet to bathtub, and it diverts water to shower head as it has no where else to go, as the door has been shut. Think of a "T", if you have water coming in, it's going to go out both openings if nothing stopping them, and they are at same level, but when you plug lower one, the water flows up and out the other. My guess is your getting very little pressure from head when it's still coming out at tub.
NOTE: before attempting this, make sure you incoming water supply to house is shut off at valve. Anyway, those spouts are usually held on by a set screw up under bottom side of faucet near back of it, (close to tub) there should be a small slot which will probably be an allen head or philips. You back that screw out, then twist and pull and it should slide off of copper pipe. If no indication under there of a set screw then there are also those that just thread on, which requires you just turn faucet counterclockwise to remove. Replace entire piece all in one, and be done with it. Most hardware or home centers will sell just that separate. Make sure you get the one with diverter. (handle that you pull.) Clean pipe well with steel wool if it's dirty and corroded before sliding new one on, and wipe some "vaseline" on pipe to help and protect "O" ring inside spout. Slide new on on all the way and tighten set screw on underside. If threaded, clean threads, add pipe dope or teflon tape and thread it on until aligned and tight. Good Luck.
Posted on Jan 28, 2011
Shower won't work
Sounds like calcium build up. remove the shower head and clean calcium or replace the shower head. Let me know if this helped.
May 12, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
The pull valve that directs the water from faucet to shower head is stuck. water leaks from shower head and can't turn it off with faucet controls. when main water line is turned off, the valve moves...
it is full of lime and scale from mineral deposits.
either chip it away to clean or remove and replace the spout with a new one which is the easiest thing to do instead
Aug 20, 2011 | Jacuzzi Home
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Bathtub faucet leaking cant find water shutoff
sometimes you have to shut the whole house off to fix a faucet,..sounds like your in this situation,....no biggie, just shut off whole house and do your repair.
Jan 30, 2010 | Delta & Single Handle Shower Faucet
I get a leak only when the shower bathtub faucet is turned on, its not the drain nor the shower head, please help....
check the bath faucet handle and the protective cover just beneath. if the water comes from here then remove handle and lower cover & tighten the nut on the insert and test without the cover
Aug 19, 2009 | Home
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
No shower water
the spout is also the diverter which sends the water up to the shower head. Assumming that the shower head isn't clogged with lime you should be able to solve the problem by removing the spout and taking it to a hardware store or home depot for a replacement. Most spouts just unscrew but some have a set screw which holds em in place. Look for the set screw on the underside of the spout. good luck
Jan 18, 2009 | Price Pfister Ashfield Single Control...
Delta & Single Handle Shower Faucet  Logo
391 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
