Question about Tanaka Garden
There is no spark from Tanaka THT210 it needs anew coil where do I get one please
Tanaka chainsaw piston probs
Hi
You try this
http://www.powerequipmentandparts.com/parts.htm
thank you
Oct 10, 2008 | Garden
How to start tanaka chain saw tcs33eb/16
take the plug wire off the plug, remove the plug, put the plug wire back on the plug and earth the plug somewhere on the metal body, pull the starter and see if there is a spark between the plug contacts, make sure the power is on when you try this.
I there is spark, replace the plug etc and check the fuel line as they do become brittle due to the heat from the motor over time and they will crack allowing air to be sucked into the carbi instead of fuel.
Jun 19, 2014 | Tanaka TCS33EB/16 32 cc Gas Powered 16-in...
My 1994 chevy astro van is turning over but won't start,i installed a new coil and anew distributor but there is no spark at the coil to the distributor
their are two spark control features one is the pick up coil it's mounted under the distributor the other is in the distributor it the control module check the pink wire that plugs into the distributor for power
Aug 27, 2012 | 1994 Chevrolet Astro
Tanaka TBC 160- very hard to start, any suggestions for possible reasons? Replaced the gas mix but it starts up & then stops running. tried new gas mix, checked throttle- seems to operate, Any...
hi there
paul 46 here.
all being well and compression and spark and timming , muffler is clear , carby is clean , and diaphrams are all ok , fresh mix , and fuel filter and lines are good
does the unit run with 2 stroke mix in the plug hole - ?
if yes assume compression and spark are ok,, if no check compression and spark and muffler
will the unit run with 2 stroke mix sprayed into the carby throat ?
if it does sounds like you have a air leak somewhere in the intake system
could be at barrel base gasket, c/case joint, manifold boot/ block gasket, carby gasket , impulse hose ,if this unit has one , c/case main seals leaking
2 strokes need air tight c/cases in order to pump fuel / air / oil mixture from c/case to cylinder
and to create a vacuum for entry of fuel/ air / oil mix from carb to c/case
symptoms of air leak are -: hard to start, wont idle, stalling, low power, inconsistant idle, over rev
overheat
pressure and vacuum testing can be done by blocking off intake and exhaust with rubber and metal plates , then fitting adapter to spark plug hole , and placing piston at bdc , pressureise cylinder to 7 to 8 psi of pressure and check areas , base gasket, manifold joint, main seals, , impulse hose ? for leaks with soapy water - if leaking bubbles will be evident
if no leaks and pressure is held at 7 psi for at least 2 minutes with dropping - presure test is good
next do the same test using vaccuum again go to 20 - 30 inch / vaccuum
if vaccuum held unit is ok
suggest take a good look at carby particularly if P and V test are good and spark coil tests good with a coil load test using a spark gap of 6.00 mm to stress the coil ( simulates spark under compression load)
have a look and let me know what you find
cheers pauly46
Apr 30, 2011 | Tanaka Commercial Grade "Inspire" Design...
Chipper was running great then shut down...now there is no spark...what might be the problem?...it was new this past spring
Use a spark tester and make sure there is no spark.If there is not then you need a new ignition coil.Take the side cover off and you will find the coil above the flywheel.remove the two screws and the wires to get it out.when you replace it you will have to set the air gap at .010-.012.most of the time when you buy anew one it comes with a guage with it.if not take a piece of metal or thin piece of cardboard that measures the right size.put new one back on .you should be able too slide it up and snug the screws enough to hold it in place then put your gauge in between the coil and flywheel.turn the flywheel until the magnet is in line with coil.loosen screws and the magnet will pull down the coil on top of gauge.tighten screws and rotate the flywheel to get gauge out.
Dec 19, 2010 | Troy-Bilt Chipper Shredder
Parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Garden Logo
79 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
