Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio TV no picture, it will come on and has some display but no picture at all just a grey looking screen. Cannot even see displays when switching from HDMI, AV, etc. This happened after a lightening storm. Not sure if it is worth fixing or how much it will cost but the set is only about 18 months old.
  • 443 Answers
Vizio panels are especially delicate when it comes to under or over voltage spikes, I would say that the LCD panel has failed and will probably cost approx. 80% the cost of a new television, I have experienced that Vizio TVs are a tuff one to get service on in my area, so you might call vizio direct and talk with one of their service reps.
GOOD LUCK !
Posted on Aug 23, 2010
I have a Vizio model M651d-A2r that will not turn on and is unresponsive. As soon as I plug the tv in, the screen displays a horizontal line, a slope line, and a vertical strip of white (see picture).
it is still under warranty ?
One Year Parts & Labor; Free Lifetime Technical Support
ring tech support first
http://vizhdtv.com/contacting-vizio/
first sight of picture says cracked in behind screen
unresponsive is worse
if it doesnt show a picture at any time
looks replace a circuit board or the flat panel
cost of used/ referbished units
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-Smart/dp/B00CBQNB7K
May 18, 2016 | Vizio Televison & Video
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Feb 11, 2016 | Vizio VO370M LCD TV
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Picture doesn't fit the screen
Its a function of the source and the tv picture settings. Go to the source (direct tv, cable, co-ax?) menu , settings and look for screen display sizes.
Your remote has a red dot "wide" button which will also have a screen size effect. You can cycle through the formats
For further info why not read/print out the manual?
http://store.vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Mar 19, 2014 | Vizio L32 32 in. LCD HDTV
Vizio xvt473sv sound, but no picture (displays glows)
are you using a cable box? tried to reset first. if still the same problem, at this time you will need to remove the back cover to access the internal part. then look for the screen back light which need replacement.
Oct 16, 2012 | Vizio XVT473SV 47 in. LCD HDTV
How do replace a broken screen on a Vizio E420VL 42 in HDTVReady LCD TV
Screen is part of the display panel and means set is finished---cost of part if even available exceeds at the wholesale level the cost of a new set.
Plasma and LCD sets have fragile display panels and can easily be destroyed.
Apr 18, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Vizio P2 42 in. HD-Ready Plasma Television Logo
436 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
