Question about Kenmore Washing Machines
Front load washer goes on but signals are not functioning
  • c_m_hamilton Aug 23, 2010
    C4917-Model #Kenmore 3.5 -Quiet Tumble Action Wash-Easy Access-I have tried all the options???
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the manufacturers name and model no# of your washer and also elaborate on your issue for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
  • Rylee Smith
    Rylee Smith Aug 23, 2010
    Thanks for your reply. The issue seems to be with the control panel that has gone bad and should be replaced however, before replacing the control panel you can take the screws off and try to blow air with the help of hair dryer so that if there is any moisture it blows if off.
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not working because the control signal is on. what should i do?
Hi, Hit and hold the volume button until the control light goes out. If you have any other questions please feel free to comment. Mike
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you reset the control lock?
book said to hold the end of cycle signal button for three seconds or when the control locked light goes out, good luck
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Front load washer
check holes under cover for obstruction in dispenser drawer. then check valve operation. there is a handy diagnostic for this. find techsheet on wall on lower left side. set dial to touch up, make sure all leds are off, then press/hold pause/cancel and options within 5 secs of turning off. refer to tech sheet for dial functions, each dial positon back turns on different function.
Apr 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer won't spin properly
It may not be draining properly, open the bottom front access panel ,3 screws on bottom front , remove the large filter access and watch for water spill.
clean of any debris. while down there check pump impellers for freedom of movement.
reassemble , then check under the rubber skirt and be certain no objects got under the tub.
Feb 27, 2008 | Danby DWM5500W Front Load Washer
Washing machine
press and hold the unlock button for several seconds. that will unlock it. However, mine still won't start in any mode.
Jan 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
