Brightness/contrast box on monitor keeps coming on screen
    Master:
    Sergeant:
  • 460 Answers
It is a problem with monitor menu button.If you can clean this button your will be solved otherwise you can check it from service center.
Posted on Aug 23, 2010
5 Suggested Answers
  • 238 Answers
SOURCE: brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Posted on Dec 15, 2007
  • 3 Answers
SOURCE: relisys 17in tft monitor
I have fixed this problem (I think). I noticed That if you hold the menu button down and swith the monitor off and on the box goes, as soon as you let the button go it appears again. So I have jambed the button in with a slither of plastic cut off an old credit card turned it off and on and it appears to be OK. If it holds up I will super glue the button down. Better than someone elses suggestion which was 'Buy a new moniter' very helpful!
Posted on Jan 29, 2008
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
  • 732 Answers
SOURCE: brightness/contrast pop up,options toggling randomly can't select
sugars_30, You or electronics technician will need to (most likely) fix the units "switch-mode-power-supply" !!! Do some extensive reading in my fixya profile and follow the links to other "cold-cathode-fluorescent-lamp" back-lit lcd monitor tech's here on fixya. They and I already have written tons of stuff that will help you to understand the problem you have. When "strange stuff" starts happening with a ccfl lcd display, the first place to look is at the innerds of the monitor. Just do some reading!!! 12fixlouie
Posted on Apr 16, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Brightness and contrast light keep coming on
The up/down button on your flat panel is stuck. Please contact Hannstar Technical Support to have the monitor replaced if its still within warranty.
May 19, 2009 | Computers & Internet
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Brightness and contrast screen in center of monitor and can't remove it
Dec 15, 2007 | Dell E173FP 17" LCD Monitor
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
513 people viewed this question
David Payne
David Payne
