Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Where exactly is the positioning button to change the discharge position? Thanks, Ed
    President:
  • Hayward Master
  • 1,378 Answers
In the plastic ring attached to the front of the motor. It looks like this:
John
Posted on Aug 27, 2010
  • fred791 Jun 20, 2011
    Thank you for pointing this button out. (It certainly doesn't look like a button.) I was unable to press this buttin with my thumb or finger and get the pump to swivel. However, I pressed it down with a large straight-edge screwdriver and was then able to get it to swivel. Thanks again.
The windshield washer spray button wasn't making contact. I replaced the wiper control with a junk yard part. It was likely from a 2001 model. It looks exactly the same as the old one.
First thing to do is to get rid of the part you put in, because obviously it's not right. Replace it with the EXACT SAME part, and you should be OK.
Feb 07, 2016 | 1997 Ford Expedition
All my electrics failed on my bike after a short ride I turned the bike off went to star it again but completely dead. Any ideas thanks
Hi, Steve and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Good luck and have nice a day.
Nov 20, 2015 | Motorcycles
Battery discharging after solenoid and alternater change
running it should be charging at 14 plus volts. if it isnt the alternator is toast. 12.6 at rest is ok
Jul 23, 2017 | 1991 Ford Bronco
Where is the button located on the pump housing to change the position of the water discharge?
I just checked on mine...actually had the discharge move a bit.
Looking from the motor end, on the right side where the motor meets the plastic pump discharge housing there is a square tab about 1/2 inch x 1/2 inch. Push that tab in using your finger while jiggling the discharge housing. It will click in and the discharge (and inlet) will rotate and click into the next position.
Gary
Jun 26, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
I have the pentair 011523 whisperflo and our spool is going to overflow from all the rain we have been having. I know that there is a way to attach a hose flip a switch and drain some of the water to...
To drain the pool, you have to change the position of your "backwash" valve.
Shut off the pump.
See if there is a DRAIN position on the backwash valve.
You could probably use the BACKWASH position, too, only water will go through the filter and then out the normal backwash pipe.
Turn the pump on briefly to see which pipe water comes out. Shut the pump.
Put discharge hose on that pipe.
Turn pump on until pool is low enough.
Return backwash valve to filter position.
Gary
Dec 19, 2010 | Pentair Pool & Spa
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Sanwa 460-ED Multitester
I am not familiar with that particular meter but.... to measure resistance you will need an ohms scale.
the leads should be plugged in to the + and - holes. Normally the red lead always goes in the + lead.
If there is a switch to change scales, do the following. Touch the ends of the test lead together, (after you have connected the leads to the meter. Rotate the switch thru all of its positions. if you see the
meter swing over towards zero, that is the ohms scale position. There should be a knob to zero the meter when the leads are touching.
Come back with any questions and I'll respond Loringh
Sep 02, 2008 | Measuring Tools & Sensors
Positive or negative
It normally says on the case of the radio where the plug inserts. If not, get a DC Voltmeter and carefully read the voltage and observe the polarity of your test. Most radios have a positive tip polarity. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 12, 2007 | Radio Communications
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
306 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
