When I try to reinstall my router I can't get beyond the first step as the disk thinks our computer is not connected to the internet when it is. It convinces my computer that it is no longer connected. But, when I unplug my modem and then plug it back in I have an internet connection. Is there something wrong with Linksys installation disk?
    Sergeant:
  • 221 Answers
Step 1: Turn off your computer, router, and disconnect the power to the modem.
Step 2: Connect one cable between the modem and the router's internet port
Step 3: Connect another cable between the router and the computer.
Step 4: Turn on the computer, then the router, then the modem - in that order.
Step 5: Now try running the setup disk.
Explanation: The modem has a security feature that disallows more than one device from connecting to it at one time. Once a specific device is connected, the modem expects that device to be connected at all times. If you unplug your computer from the modem and plug in the router without disconnecting the power to the modem, the connection will be rejected. This probably explains the reason for the error message you were receiving.
Furthermore, you do not need the installation disk in order to install your router. Open your browser and type http://192.168.1.1 in the address bar. A username and password screen will appear, the default is usually admin/admin for both, but if that doesn't work just try admin in the password field. When you have successfully logged into the web utility, you will be able to alter the settings at your discretion. For the most part the router will work upon proper cable connections, however you will want to enable security features to prevent attackers from gaining access to your computer.
Posted on May 04, 2008
Wired internet connection not working
you must reset the router by 30 seconds and try again. Remember they have a password for wep key for access. do you do it?when you installed the router the software is you want the connection close or open?
However you must click in open network connection , and select network troubleshooter and fix it.
If the problem remain, you must go to router supplier manufacturer via ONLINE chat, and explain the problem.
or reinstall the Router again follow the steps with your disk instalation.
God bless you
Jul 28, 2013 | Zoom Computers & Internet
I'm trying to reinstall the Dlink via the disk, getting error 112
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Unable to connect my mac to d link worked ok until new modem was installed now will not connect mac computer sends a message you are not connected to the internet. have tried rebooting the...
Then you need to connect the computer to the router ad the modem to the router.
Jan 29, 2010 | D-Link DIR-615 Wireless Router
Limited or no connect
Hi i'm Rain.
Limited or no connectivty means that your router is not picking up the connection or it is connecting but may have something blocking the connection.
To repair this you will need to reinstall the routers drivers to your computer. You should have a disk that came with the router. Use the disk to reinstall the needed drivers to connect to the internet.
If you do not have the disk , the easiest way is to call whom ever you got the router from and have them bring the disk out or go pick the disk up. Always remember when you have a router installed by a company the disk belongs to you. Most times the technician will not give you the disk because that way you will have to call them to come out to reinstall it. Thats more money outta your pocket.
Nov 29, 2009 | Linksys WRT160N Wireless Router
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Lost internet connection via cable modem-router-tower
Alright, start with the basic Gateway IP. http://192.168.0.1 That is what i use to access my router's (yeah, we run just a few more computers than normal people) Anyways, If that doesnt work, then the router has been changed beyond a normal spectrum of Ip configurations. Next step is to recontact Linksys and Let them know directly that the IP Address for accessing the router is not working. Meaning you have no Access to the router at all. Almost all routers use the same base access router ip setup. Its rare to find different unless you are like a few people, who find they need to run at least 2 or more routers on the same internet connection because of too many computers.
Otherwise, follow this link:
http://lifehacker.com/software/feature/special-how-to-access-a-home-server-behind-a-routerfirewall-127276.php
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 06, 2008 | Zhone (6218-I2-200) Router
My son installed this new router that I paid for just about a week ago. It is the Linksys and there are 4 computers including this one that is mine connectng to it. The router fails every few days and my...
hello!
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 20, 2008 | Linksys Wireless-G WRT54G Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
