Question about Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator
Fridge is not cold -temp sitting at 17 c - Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator
  • Liebherr Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
Fridge is too cold
It needs a new thermostat
Jul 27, 2013 | Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
Fridge wont get cold
unplug for 15 min let sit the plug back in u should here it turn on feel the sides of the freezer if getting cold but fridge not the fan for fridge bad also there should be a copper or steel looking wire inside in back for therm
for the temp move it around it mite work if not condecer low or bad
Dec 17, 2011 | Kenmore Refrigerators
Our fridge Liebherr KBES 4260, Class SN-T is located in a utility room that is not as warm as the kitchen, but neither is it bitterly cold. During the very cold spell in December and in January it failed...
most modern f/f work in the temperature range +10C to 35C,so if you store it in a room below or above these temps you will incounter problems.before you buy you should check the temp range as in some countries they supply them to operate outside these parameters.i use a greenhouse heater in an outhouse to keep mine warmer than +5C,seems to work okay.
Jan 26, 2011 | Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Freezing in the fridge in the salad tray [behind]
If the fridge is not set too low there are a couple of fixes. First test the temp in the center of the fridge with an accurate thermometer. If it is registering below 35 in the center of the unit, set it to a warmer temp.
If it is cooling in the 35 to 41 range the setting is good. Then you should clean out the fridge and shut it off. When it reaches room temp. place several pans (like cookie sheets or cake pans) of boiling water on the shelves. Allow it to sit with the water overnight (door closed) The next morning remove the water trays and wipe off any moisture that has accumulated inside. Restart and then (when cold) restock. The issue should be resolved.
Dec 16, 2008 | Refrigerators
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator Logo
259 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
