HP L7680 starting a print job sends one sheet through blank and then cycles for a few seconds looking for paper then comes up w/ error msg asking me to load paper. I've turned it off and on, reset it to factory settings per your instructions, and it's still doing the same thing. Last try after reset it sent through one blank, then the second page of the email, and then wouldn't pick up paper and gave me the error.
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
