Question about Toshiba 62HM95 62" HDTV
I have an 62hm95 I replaced color wheel but broke a small piece of glass bout 1 inch by 2 inches in the front of the colorwheel housing on the side where lamp shines through. the piece i broke just sets in a grove on the housing in is not attached to it I cannot find the name or part number for the glass anywhere any suggestions or assistance will be greatly appreciated
  • Toshiba Master
  • 11,800 Answers
That piece of glass is the first lens from the optical engine and it's glued in position.Glue it back or the entire engine will have to be replaced at a great expense.
Posted on Aug 23, 2010
Cartridges will not engage
Check on the left hand side where the cartridge slides in there is a small swivelling retaining triangle of plastic that is lifted up by a thin plastic rod (hidden) when the front door is opened. if this triangle becomes detached from the hidden operating rod then that cartridge will not lock in. the problem appears to be on the right side but it is this left triangle causing the problem.
simply locate the small plastic triangle and attach a 6 inch piece of scellotape to the triangle so you lift it up to allow the cartridge to slide and lock in place. then give the scellotape a sharp tug and it will come free and the small locking triangle will drop down in place and the cartridge is locked.
Nov 11, 2012 | HP LaserJet 3600n Printer
Its a toshiba 62 inch rear projection model # 62HM95 the small glass piece near color wheel is broke was told that piece is the al top mirror is that the name
Visit this website for List of Parts/Part#
Encompass Parts Distribution 1-800-638-3328
They offer free Service Manuals to some Models.You can Print them out online.
Apr 12, 2011 | Toshiba 62HM95 62" HDTV
Location of therma stat
The location of the thermostat for most vehicle.
Stand in front of the car with the hood open, you'll see a black hose hooked to the upper side of the
radiator.( about 2 inch in diameter, newer vehicles about 1 and 1/2 inch, and newer small cars
about 1 and 1/4 inch. ) Follow the hose to the other end, it connects to the thermostat housing. The thermostat is inside of the housing.( the hose usually goes to the air intake manifold, but some
housings are on the side or back of the engine. )
I hope this helps you.
Feb 02, 2011 | 2006 Chrysler Town & Country
Screen is red instead of blue i just changed the color wheel and now it works but its off color
there is a jumper on the DMD board, the one that the colorwheel plugged into.. there is a small window to pull it out.. if there isn't one, then you have to add one. there was 2 types of colorwheels on this set, jumper tells it which one
it looks like this, its like 1/16 inch, so this is way oversized. sometimes if you can't see it, you have to remove the shield (only saw once, i think it was a manufacturing mistake) let me know if you need further assistance
Jun 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
When i turn my tv on it sounds like a high pitched wine...is it the motor?? Still turns on no picture quality issues just a loud noise that accompanies the picture
Thats your Color wheel But acorrding to what I researched you have to Replace the whole optical Module part# 9NK3797086200 which is optical module,light Engine & Colorwheel Encompass Parts do not have it in stock but they List its Price $1,930.00 core refund $1,030.00 cost of total replacement is $900.00 you can call them to find out 1-800-638-3328 or try UED 1-800-648-6657. See if you can just replace The Color Wheel itself because that is what is Bad! OR are you better off to just replace the whole unit!
Dec 03, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Ok, so i thought i could fix it, now i need help. Problem 1. My tv was buzzing and sometimes the color was weird when you first turned it on. Then after about 30 min. all was fine. Well one day it just...
When the Color Wheel Motor does not turn any more the set will shut down. The only way to my knowledge to fix it if this is what is happening is to replace the Optical Block. It consist of the Color Wheel and Optical Path as one unit and it is expensive. I estimate 700.00 to 800.00 maybe more. You could try to price it through Encompass Elect. 1800-638-3328.
Hope this helps,
Skyassoc
Dec 02, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Need to replace broke window on 93 ford tempo.Pass. side
Door Glass, Front Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05. ani_caut.gif CAUTION: Prior to removing center pins from the rivet, it is recommended that a suitable block support be inserted between door outer panel and glass bracket to stabilize glass during rivet removal. Remove center pin from each rivet with a drift punch. Using a 1/4-inch diameter drill, drill out remaining rivets as damage to plastic glass retainer and spacer could result.
  1. Remove two rivets attaching glass to run and bracket assembly.
  1. Remove glass.
  1. Remove drillings and pins from bottom of door.
Installation
  1. Snap plastic retainer and spacer into two glass retainer holes. Make certain that metal washer in the retainer assembly is on outboard side of glass.
  1. Insert glass into door.
  1. Position glass to glass bracket. Install two rivets to secure glass to glass bracket. NOTE: Two 1/4-inch-20 x 1-inch bolts and two 1/4-inch-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (36-61 lb-in). Equivalent metric retainers (6mm) may be used.
  1. Install door trim panel and watershield. Refer to Section 01-05.
2-Door Vehicles
4-Door Vehicles
May 29, 2009 | 1993 Ford Tempo
Color wheel
wrong color wheel..there are 2 colorwheels.you will need to remove a jumper wire...jumper is inside an opening abut 3/4 inch under label.
Apr 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Toshiba 62HM95 62" HDTV Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
