Question about Panasonic PT L711U Multimedia Projector
Projector Doesn't Power-ON
Panasonic PT L711U
Bulb has 1750 hours.
Since last 3 months, I was having problems with intermittent "ON" and "OFF" of the bulb and I was speculating on replacing the bulb. I wanted to make sure the bulb is really at the end of it's life.
Couple of days ago, the projector completely went dead, while watching a movie. I suspect, I might have pushed the projector back to the wall. Now the power doesn't come "ON" at all.
Is the projector is completel DEAD ? Anyway to salvage it ??
- BK
  • 563 Answers
Hi bmosai
Yes you will have to replace the lamp.
The Projector will shut down and stay off as a safety feature.
Posted on May 06, 2008
How to rest alamp hour on panasonic tv with a universl remote model pt 432-c14
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Panasonic ET-LAM1 Projector Lamp for...
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
I have a new light bulb 7 months ago and i only have about 100 hours on it why will my projector not start
Have you reset the lamp timer?
If so, what is the status of the indicator LEDs next to the Power button?
Aug 15, 2010 | Panasonic PT-AX100U-EC DLP Projector
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic pt l711u power will not stay on
That used to happen to my PT 711U until I put in a new air filter. After that, no problem.
Dec 28, 2007 | Panasonic PT L711U Multimedia Projector
Panasonic PT L711U Multimedia Projector Logo
229 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
