Question about Peg Perego John Deere Gator HPX Ride on Toy
We have an older model, 5 years or more. Sometimes it works and other times nothing happens when the pedal is depressed. Sometimes moving the shift lever back and forth helps. Sometimes it works in reverse, but not the forward gears.
    President:
  • 670 Answers
Sounds like the switches need to be cleaned/replaced. Try peg-peregoparts.com for the parts that you will need.
Posted on Aug 23, 2010
Key programing toyota 2002
No need to panic rush through this procedure, just do it right. Haste makes waste.
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert an original Master Key into the ignition but do not turn it.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert New Key into ignition but do not turn it.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. Now sit and wait for about one minute until the security light in the center counsel stops blinking and turns off.
8. Remove new key and depress and release brake pedal 1 time.
9. Test your key now. It should work if you followed the instructions. If not, you may want to try the following instructions:
This procedure is for 2002 Camry and most other models in this year of Toyota. In the future always give the model as well as year and make. Thanks
Nov 06, 2016 | Toyota Cars & Trucks
Pedals stopped working.
If electronic trace the cable back to make sure connection is secure. Sometimes there is a button that turns sustain off, check control panel to make sure it is switched on. If piano is acoustic take off front panel beneath pedal board to make sure wooden rod is still connected.
Dec 24, 2013 | Music
I have a 2005 Nissan Altima will not shift out of park.I have replaced the shifter assemble,brake lights do work,Need help
If the floor shift lever wont move out of park, there foot brake lock that prevents it from moving until you depress the brake pedal and pull it out of park. I think the release is vacuum operated so try depressing the brake pedal a few time while trying to release. TerBo
Jul 29, 2011 | 2005 Nissan Altima
Won't shift out of park
You probably have a defective brake light switch. The brake light circuit controls the shift interlock. This is made so small children cannot shift the vehicle out of park....You have to step on the brake and work the shifter at the same time...little kids can't do that. Anyway, check your brake lights to see if they are working. If they are not working, this is your problem. The most likely cause would be the brake switch mounted under the dash on the pedal assembly.
Feb 19, 2011 | 2001 Ford Escort ZX2
I have a 2008 Chevy aveo, and it will not come out of Park.
There is a switch behind the brake pedal that is not functioning. There should be a little port near your shifter marked "Shift Lock Release" or something similar. Pry off the cover and insert your key. Engage your parking brake. Remove the key and proceed to start your car. You will need to do this for every start until you replace the faulty switch. I had this happen to me last year. The switch cost me $5.
Dec 16, 2010 | Chevrolet Aveo Cars & Trucks
When I start engine and depress brake pedal and go to move shift lever I can't depress shift lever button to move out of park. This will happen 6 times out 10.
2002 chevy trailblazer on neutral mode, trailblazer can be pushed easily,but shifter is stuck on park. vehicle will start.the push button on shifter will not engage
Sep 09, 2010 | 2002 Chevrolet TrailBlazer
Hello. I've an older mtd Gold series tractor 14/42 model 133M660G513 serial # (mf code) 1A22313-0177. Last year near the end of the season I noticed it running great but having a bit less power going up...
check and be sure there is no oil leaking from the engine on the belts and the belts are not oily. inspect the drive belts. as they get older they crack and stretch and don't work as the should. replace the belts as you said it is a older machine. there is nothing wrong with a older machine they just need attention every now and then.
Mar 07, 2017 | Garden
I bought my car, used, from a dealer, earlier this year and since, it has had no problems. Over the past couple months, it has started doing this. I am not a car guru by any means, so this will all be in...
shift safety lock not disengaging,holding it in park,temp gauge may just be temp sender,you can disconnect and earth out the temp wire to see how the gauge moves to see if its ok and its the sender
Oct 27, 2009 | 1997 Saturn SL
1987 Suzuki Samurai Clutch problem.
Adjusted Clutch cable assembly under passenger side of vehicle. Had assistance from friend depressing clutch pedal and engaging shift lever. Problem went away
Mar 18, 2009 | 1987 Suzuki Samurai
My 20002 mustang v6 its automatic
To shift from "P" to "R", there is a swicth that allows the shift button on the shift lever to be depressed. For this switch to work, the ingnition switch must be "ON" and the brake pedal depressed. If all yor brake lights went out (or if your brake switch on the pedal fails to work), then the shift switch wont work and you can not shift out of "P".
Jan 26, 2009 | 2002 Ford Mustang
Peg Perego John Deere Gator HPX Ride on Toy Logo
132 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
