Hello, Can the casing that the thermostat is in be replaced? and if so what is the name it is called so i can get one. Thanks Damain
    Novelist:
    Champion:
  • 266 Answers
Sorry but you will have to buy a new thermostat as a unit. You can not buy the casing by its self.
Posted on Aug 23, 2010
  • db_bowen22 Aug 27, 2010
    thanks. Is it called the thermostat housing or the engine coolant water outlet?
  • allen_haney Aug 27, 2010
    Hey your post was under home air conditioner. On a car yes you can buy the thermostat housing. Its kind of a non wear item but you can get a replacement one at any autoparts store. Just take your old one with you or they can look it up by year/brand/ ect.. good luck
My tv has a aprx 3" wide black stripe on screen, the stripe is verticle and is always there with tv on. is it worth fixing? thanks
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} in most cases this will be a bad buffer module. this board is called other names but they all do the same work.but a cost will range around $500.00. in some cases it is the display itself and a cost would be more than you paid for the unit. but this is not common.
good luck...
May 24, 2010 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Replacing analog thermostat with digital
alot of those gas fireplaces work on what is called powerpyle or 750 mv if your old thermastat has a ts in model then you would need tstat that works with millivolt systems
May 04, 2009 | Honeywell Electronic Programmable...
What temp is the thermostat meant to open for 1993 Subaru Legacy?
Hello jamesthomasd, my name is JShreader. Thank you for choosing fixya.com.
The Thermostat Opening Temperature for your 1993 Subaru Legacy Wagon F4-2.2L SOHC is 173°F.
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Apr 01, 2009 | 1993 Subaru Legacy
I can't find the thermostat on my 2001 Dodge Caravan. Can someone help?
Hello jhenry246, my name is JShreader. Thank you for choosing fixya.com
The Thermostat is located behind the Thermostat Housing on almost all Vehicles. There are 3 different Engine types they used in this Caravan this particular year. I have uploaded you pictures showing the locations of the Thermostat and Housings for each Engine in .pdf format. You can download them by clicking HERE. The engine cooling thermostats are a wax pellet driven, reverse poppet choke type. If you follow the Upper Radiator Hose up to the side of the Engine, it connects to the Thermostat Housing.
You must drain the Cooling System before you remove it. I went ahead and made you up the replacement procedures for replacing this Thermostat. You can download it by clicking HERE.
Mar 31, 2009 | 2001 Dodge Grand Caravan
Torque specs
Hello mikemcgee63, my name is JShreader. Thank you for choosing fixya.com.
The Torque Specs for the Thermostat Housing are 10 Nm (89 inch lbs.).
Mar 30, 2009 | 2001 Chevrolet Corvette
Replace thermostat 2003 kia spectra
Hello, my name is Mario.
1. Disconnect battery negative cable.
2. Drain engine coolant
3. Remove bolt and nut for thermostat housing
4. Remove the old thermostat
5. Put a new thermostat and gasket (Install thermostat into cylinder head with jiggle pin positioned up.)
6. Place thermostat housing
7. Fill radiator with engine coolant
8. Connect battery negative cable
9. Start engine and check for leaks.
Good luck
Jan 10, 2009 | 2003 Kia Spectra
No picture
Don't waste your time trying to figure it out Call a factory service and let them do a warranty repair. This set is too new to have problems and there may be updates to it that will prevent further trouble. The inverter board is probably bad and if you try to go out of pockket $$$$$ big time. Go for the free repair.
Jun 26, 2008 | Vizio L32 32 in. LCD HDTV
Settings
follow sequencelly on your phone .go start>settings>tap connections which is given on bottom of the screen.there are many options on the screen but you select "connections".In "My ISP" select "add a new modem connection" option.fill the name for the connection which is given by your service provider .& select a modem from the list.go next>fill name of connection in acces point.go next.fill up phone number or credit card number which you remember.go next>fill up user name>password>damain.tap finish.
Nov 09, 2007 | i-mate JAMin Smartphone
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
