Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
My computer no longer reads the presence of the hard drive ( i can not open it and it no longer appears on my computer). However the safely remove hardware function seems to know it's there, but i can't actually gain access. I have tried it on other computers to the same effect. i have many precious files on it and would be delighted if you could help. cheers tom
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Posted on Aug 23, 2010
Computer can no longer read external hard drive. How do I reboot it
It's likely you now have a damaged partition. It's a common problem. If you don't care about the data just reformat.
Or you can try http://findandmount.com/
Or get data recovery help remotely from http://FreeDataRecovery.us
Aug 07, 2012 | Western Digital My Book Essential Edition...
When i open the laptop which is lg with model number lgc50,a message appear,and it says press f11 to begin lg recovery,and suddenly another message appear that says.....disk read error
Please check if you have any disk in your CD/DVD drive, if not then the issue is likely with the hard disk drive (which has all your data). We have to check if the hard drive has gone bad completely. Please take your computer / hard drive to a local technician and ask them to backup your data if possible. Then you have to replace your hard drive.
Aug 01, 2011 | Computers & Internet
The flash drive no longer operates on the computer, though the light flashes.
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management.Thenright click on Disk 1 removable drive and click Format. After the flash drivehas been formatted it will indicate that it is Healthy.
Jul 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can no longer locate my removable hard drive when I hook it up to the computer. It used to work just fine; in fact I've got stuff on it I want to access...but my computer will no longer read it. The...
Double Click My Computer to see if you can see the removable drive. If its not there, right click my computer, manage, disk management. Look for a drive without a drive letter. Right click the drive, click on "change drive letter and parts", click on add. Choose a drive letter and click ok or apply as the case may be to get your pc to recognize your external drive.
Feb 04, 2011 | SimpleTech 1TB External USB 2.0 Hard Drive...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
I used my hard drive with great success for a while now, switching it between several computers. Today, however, it wouldn't register anymore, my computer won't see it. It makes the sound when i plug it...
Sorry to inform you that the HD is starting to quit working. Clicking sound is the indicator that it's no longer responding. There could be some bad sectors in the HD.
You may want to check the Disk Management of your computer to see if you could still reformat the HD. Bear in mind that reformatting the HD would erase all the files saved in it.
1. Connect the HD to the computer.
2. On your computer screen, locate "My Computer" or ""Computer" icon and right-click on it.
3. Click on Manage and then select Disk Management.
4. Write down all the drive letters that would appear.
5. While the Disk Management is opened, unplug the HD and see which drive letter would disappear.
If there's no drive letter that disappears, meaning that the HD is no longer recognized by the computer.
Try bringing you HD into any computer store that offers data recovery.
Aug 07, 2009 | Western Digital My Book Essential 1TB...
My computer's safe mode is not working what is the cause of this problem and how this problem can be solved.
Do you completely power off the computer or just use the Windows
Shutdown command and/or the On/Off power button on the computer?
Try totally shutting off the power by switching off the power bar or
unplugging the power cord from the back of the computer. Leave it for
5 minutes then power it up again.
I just "fixed" the exact same error on a customer's computer this
morning.
When a computer is shutdown but the main power is still live there is
still some standby power being passed to the motherboard. Therefore
some of the motherboard components will have an electronic charge
present and this can cause the problem you have described. By totally
disconnecting the power for 5 minutes the motherboard will discharge
completely, thereby clearing the problem.
Another possbile cause of this type of problem is a USB device, such
as an external USB hard drive or a USB memory stick being left
connected when the computer is powered up. Somehow the boot device
sequence can get corrupted by this presence and the computer tries to
boot from the USB device and fails. Unplug any USB hard drives
and/or USB memory sticks and see if that resolves the issue.
If you can boot your computer normally, there is another way to boot into Safe Mode with Windows
Boot the computer normally.
Close all open programs.
Click Start, and then click Run; the Run dialog box will appear.
Type msconfig in the box and then click OK.
The System Configuration Utility should appear.
Click on the BOOT.INI tab.
Check the "/SAFEBOOT" option, and click OK.
You will then see the prompt to restart the computer, click Restart.
The computer will then restart in Safe Mode.
When another box opens asking if you want to run in Safe Mode; click Yes.
Good luck
May 08, 2009 | Microsoft Windows 98 for PC
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Not able to open Kinston 2GB Pen Drive
on desktop, right click my computer, manage, Disk management. Do you see your drive there?
Mar 23, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
193 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
