Question about Archos Gmini 402 Digital Media Player
Archos gmini 402 camcorder
Got this archos gmini 402 camcorder, when i turn it on it come`s up with the loading screen (for about half of a second) then the screen goes pinky coloured and nothing else happends. can anyone help me???
ps i`ve tried taking the battrey off and also the hard drive but that din`t work. cheers mal
  • mallybanger Jun 27, 2008
    Hiya and cheers, I tried it but still no joy same thing happens, just got a blank screen . (think it could be time for the bin )
    Thanks again
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
Posted on Jun 25, 2008
Archos Gmini 402 Camcorder will not charge properly.
i think it has battery problem. its not charge properly. check its cable or other wise change the battery with new one
Jan 19, 2012 | Archos Audio Players & Recorders
I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Jan 26, 2009 | Archos Gmini 402 Digital Media Player
Unit Frozen After battery replacement
I came up with a solution (finally!). Only try this if you have exhausted all other possibilities.
First, make sure the unit if turned off, remove the backplate, and set the battery aside, still connected. Peel back the gold foil where hard drive connects to the motherboard, and loosen the small silver plate at the other end, sliding it to the side. Remove the hard drive by sliding it off the pins. Turn the unit on, and you should get a screen that asks if you would like to reformat. Replace the hard drive, carefully, and quickly, and reformat.
I had to reformat twice, but I eventually got the thing working. I was almost ready to toss it, so any extended life I get is worth it. If nothing else, this should get you off the dreaded logo screen. Good luck!
Apr 14, 2008 | Archos Gmini 402 Digital Media Player
Archos Gmini 402 camcorder 20GB digtal media player
Hi there this may seem a silly question but the ear phones you are using are a stereo ear phone? or the adaptor to your archos is a stereo one?
Apr 09, 2008 | Archos Gmini 402 Digital Media Player
Archos gmini 402
Output 5v=0.75A
negative exterior, positive interior
Feb 13, 2008 | Archos Gmini 402 Digital Media Player
Freezes on start up
If you have problems with the file system on your Gmini? 402 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini? 402. ? Quit all running applications. ? Properly connect the Gmini? 402 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini? 402. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini? 402 from your computer. Try it now and see if makes any difference,
May 22, 2007 | Archos Gmini 402 Digital Media Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Archos Gmini 402 Digital Media Player Logo
251 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
