Question about Car Audio & Video
2010 Mustang - Radio just stopped working. The display only says "Mustang" with temperature reading. It should display time, channel, etc...No controls operate. Worked fine...turned car off..15 minutes later turned on and radio dead. Dealer says radio has no lock function and they are unaware of this problem.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try disconnecting power to the radio for a few minutes and see if it resets itself. if you can't get to the back of the radio, disconnect the battery.
Posted on Aug 23, 2010
2011 Mustang radio will not turn on. Time flashes, outside temperature displays. What do I do?
You need the dealer to inspect and repair the radio through a Ford authorized audio systems repair center.
Apr 21, 2016 | Cars & Trucks
What happens if two digital thermometers are set on the same channel
The same as when you have two radio stations on the same channel or frequency. The receiver wants so receive them both, resulting in a scrambled and useless signal in the receiver.
It won't work.
If the system can work with more than one (wireless) thermometer each will have an own channel number. and you will have to switch on the display to read one or the other.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
The digital display of the time, radio station and CD stopped working on 10/29/14. What do I do?
If the display quit working and you can still get sound from the radio. live with it or replace the radio. The display died.
Oct 30, 2014 | 2009 Mitsubishi Galant
Where is the radio fuse in a 2010 ford mustang fuse box diagram?
Check 10A FUSE 39 and 5A FUSE 29 in the Smart Junction Box.
Sep 14, 2014 | 2010 Ford Mustang
2010 mustang radio issue
Mine is doing the same thing. Did you find a solution
Jan 01, 2010 | 2009 Ford Mustang
The temperature transmitter does not communicate with the receiver. In spite of: two new sets of Duracell AAA Bateries Both the receiver and the transmitter are on channel...
Hi
Thanks for using FixYa. Try changing the radio channel by--
To change to radio channel:
1. In any of the time displays, press and hold CHANNEL for 2 seconds.
2. Press or to switch between various channels.
3. When the appropriate channel has been selected, press MODE to confirm and return to the lock- Display mode.
Also see this manual for more detailed instructions--
Oregon Scientific temperature transmitter
Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 01, 2009 | Office Equipment & Supplies
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Car Audio & Video Logo
463 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
