Question about Sport & Outdoor - Others
2000 polaris genesis jet ski manual - Sport & Outdoor - Others
Dash bord indicators are inop but a lock light is on it starts and runs but won't throttle up
Posted on Jul 15, 2011
Why my Polaris sl900 1997 does have any sparks I changes the stator coil cdi box please help me
Check this site, (Disclaimer; I haven't used them, but it may have the PDF's that you'll need.)
http://www.kicksup.com/personalwatercraft/
Aug 22, 2014 | WSM 1996-1997 Polaris Sl 900 Cc Jet Ski...
Polaris troubleshooting
Have you cleaned the carbs and fuel tank , checked the plugs and coil ht's and connections ?
Aug 04, 2014 | WSM 1999-2000 Polaris Slh 700 Cc Jet Ski...
clean impellor and water intake ! run up on hose and check cooling ok !
Jul 28, 2014 | WSM 1993-1994 Polaris Sl 750 Cc Jet Ski...
My Polaris freedom(jet ski) starts and runs good
Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer. I know all these are expensive but if your going to be a polaris tech you will always need them. Troubleshooting (1) check compression. Look at your Clymer manual for specific psi.all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine
times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace and replace all fuel filters. Polaris has a gravity filter under seat, clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a C.D.ignition. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive polaris, if the problem is still there then there is further steps to take. If your polaris is fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your polaris. Troubleshooting tips and teaches you how your polaris works. If its carburetor then you should clean carburetors. Inside the carbs is another filter that needs to be cleaned. Its not difficult you just make sure you put everything back in proper order. take pictures if you need to.
Sep 18, 2009 | Boating
2002 polaris jet ski. Cranked 1 month ago with no
you need to put a new battery in it if that does not fix it you will have to replace the solenoid
Jul 08, 2009 | Boating
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Sport & Outdoor - Others Logo
618 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
